My 4L60E to TH350 swap thread.....
Old 04-26-2013, 10:35 PM
  #41
1961ba427's Avatar
Great thread. I bet you'll knock several tenths off with this set-up. That 4L60E 1st to 2nd rpm drop being gone will be awesome for you. Thanks for the pics of your modded crossmember. I've been thinking about finding a 9" tailshaft th350 and swapping it in place of the T56 for a few months just to play at the track. Should make for less broken parts and better 60' times. I've also considered a 4" tailshaft TH400 I already have and using the stock t56 crossmember. It's slightly shorter overall, but I have a few TH400 yokes that are longer than our normal 4L60E/T56 ones. I think I could just cut one of those down to the needed length and still run the stock length driveshaft.
Old 04-29-2013, 05:11 PM
  #42
BOOSTED AFR's Avatar
Did you get the car back together?
How was the track?
Old 05-06-2013, 09:44 AM
  #43
quik95lt1's Avatar
How was the track?
we actually just fixed it yesterday......wound up being a d ring on the pump stator that had to be removed, with the dual feeding direct setup in coan's valvebody the dring has to be removed to allow the fluid to get to the direct clutch pack.......coan I guess forgot to tell us this, and when I called and asked the guy said no you leave them all..........myself and my builder went through it yesterday and realized that was the issue....took it off and bam works perfectly.............we will see when I get to the track hopefully soon but ive got to go in for some minor surgery to have a cyst removed on my tailbone so ill be out of comish for about 2-3 weeks after that cause sitting isn't so comfortable lol.......ill get it out there soon though
Old 05-06-2013, 10:42 AM
  #44
Keep us posted.
I'm excited to see what the difference in weight, rotating mass, and converter are going to do for you. Should be a good ride.
Old 05-17-2013, 09:01 AM
  #45
quik95lt1's Avatar
Keep us posted.
heading up tonight for some testing.........hopefully everything goes well and stays together and the traction gods are present
Old 05-17-2013, 09:27 AM
  #46
Chopstix's Avatar
good luck
Old 05-17-2013, 02:31 PM
  #47
I'm oddly anxious to hear the results.
Old 05-17-2013, 10:05 PM
  #48
1961ba427's Avatar
Looking forward to results too. I bet you'll be reporting a new PB despite being the first time out with a new combo.
Old 05-17-2013, 11:17 PM
  #49
CamaroRacing12's Avatar
Hehe i know what he ran!
Old 05-18-2013, 09:39 AM
  #50
Puck's Avatar
Spill the beans!
I need to know how far behind him I will be when I finally get to a shootout .
Old 05-18-2013, 08:29 PM
  #51
quik95lt1's Avatar
ok ok ok lol.......so i got to make 3 passes friday night before they kicked me out because my cage isn't certified yet.....right off the trailer it ran 9.77@138.37 on a 1.33 60' DA was right at about 600ft that was off a 1800rpm footbrake i was hesitant to put it on the brake right away and stand it up......second pass i came out on the footbrake at about 2600 chattered the tires out of the hole and ran 9.78@138.5 on a 1.35 60'......last pass i made before they booted me i tried coming out at 3000 on the trans brake.....it blew the tires off so i pedaled it to a 9.86@ 138.7 ....
gotta get the cage ceritifed and move my batt to the back then ill be out for more testing..its a totally differnt car now, i need to dive back into the suspension tuning and tire pressures along with the tune.....im confident its got a decent amount more in it we will see soon.....and fwiw the clean neutral setup from coan is the *****....thing is awesome just click it to neutral after the stripe and it coasts down nice and easy no noize no nothing its a great setup
Old 05-18-2013, 09:02 PM
  #52
96capricemgr's Avatar
I am actually surprised the suspension worked that well for you right out of the gate. Figured it would take a trip or two to whittle it down. Pretty easy to upset a car at your level, glad it wasn't the case to start.
Old 05-18-2013, 09:07 PM
  #53
matt94z's Avatar
Nice!!!! Can't wait to see the results when you get it lined out.
Old 05-19-2013, 01:28 AM
  #54
Hit em Up's Avatar
Man that's impressive right out the gate!! I think once suspension is dialed in you will drop a few more tenths off easy! Good luck,and im almost ready to try out the old 4l60 in the street car
Old 05-19-2013, 08:03 AM
  #55
robsquikz28's Avatar
AND VIDS
Old 05-19-2013, 08:39 AM
  #56
BOLO's Avatar
Nice results Mike. What tire/gear combo are you running? It looks like Mod Na in the shootout is all covered once again.
Old 05-19-2013, 10:05 AM
  #57
It wasn't last year. Anyone can win even those guys from chitown :rollseyes: lol
Mike ever consider keeping the battery in the front to help keep the wheels down?
Old 05-19-2013, 08:43 PM
  #58
quik95lt1's Avatar
Originally Posted by robsquikz28
AND VIDS
29x10 and 4.56 same as before
Hey man **** happens I missed 2nd gear and got beat its all good worlds too small to hate lol...and I have but nhra rule forces me to run a rear external shutoff so I basically have to move it back.....this weekend I still had the pass seat in and I had about 10 gal of fuel in it cause I didn't feel like doing it there.....I reallywasnt set up to go nuts.....I wasn't trying to put up big numbers I was jsut seeing how the new stuff worked.....I had about 50lbs worth of fuel and seat I coulda lost but it will have to wait till next time....my next project is swapping my two rear bars on the cage for chromoly before the chassis cert
Old 05-19-2013, 10:28 PM
  #59
Very nicee u coming up next weekend?
Old 05-20-2013, 06:57 AM
  #60
9-Second Club
Ed Wright's Avatar
With Santuff front shocks you can move all weight you can to the rear and control (or stop) wheel stands also stop the bounce when landing. I had QA1s, then sent them off to be re-valved, then AFCO shocks, then sent them off to be re-valved. Still bounced, still had to have weight out front (had 65lbs out in the nose) to keep the wheel stands manageable with shock adjustments. Now I have all the weight (I have a min weight to meet, I have to go across the scales every pass) to the rear for slick tracks.
Some of the best money I ever spent.
Quick Reply: My 4L60E to TH350 swap thread.....
