how to remove crank keyway
Old 05-01-2013, 07:17 PM
Bern1982's Avatar
Default how to remove crank keyway
My keyway needs to be replaced and its not coming out. I had a visegrip on it but it doesnt move. Can i heat up the crank and pull with the visegripor what is the trick?
Old 05-01-2013, 07:58 PM
RamAir95TA's Avatar
You can get them from any machine shop so if you end up mauling it a replacement isn't far away.
Old 05-01-2013, 08:13 PM
Village Troll
SS RRR's Avatar
I've always had good luck using a hammer and punch.
Old 05-01-2013, 08:52 PM
shbox's Avatar
Yeah, if you just tap up and under the front of it, it should lift right out.
Old 05-01-2013, 09:32 PM
Bern1982's Avatar
I can't get under it. It got mangled from the reluctor wobbling.
Would it hurt the crank if I heated the crank with a torch or a heat gun?
Old 05-01-2013, 10:12 PM
shbox's Avatar
Then tap it down on one end. The other should pop up because of the half moon shape.
Old 05-02-2013, 04:39 PM
leadfoot4's Avatar
Originally Posted by shbox
then tap it down on one end. The other should pop up because of the half moon shape.
bingo!!
Old 05-02-2013, 06:32 PM
Bern1982's Avatar
I managed to get a piece of the key with a chiseland knock it back a hair the went down with a punch and knocked the back half if the key out. Thanks help guys
Old 05-03-2013, 12:29 AM
cbr600rx7's Avatar
^^^ He is right on. I had a pain in the tail trying to get mine out. Then I tried a hammer with a long punch and started taping on the key end and she came right out.
Old 05-14-2013, 07:45 PM
Bern1982's Avatar
I got everything back together now having a problem with the crank is turning tight I lined up the dots on the timing set with equal slack on each side.
Old 05-14-2013, 08:32 PM
RamAir95TA's Avatar
Well you are fighting 200psi of compression. The engine isn't supposed to turn freely you know. I am going to assume you didn't do something silly like leave the car in gear (A4 or M6?).
Old 05-14-2013, 09:01 PM
Bern1982's Avatar
No there is a big difference from when I was removing the crank hub I had to chain the puller to stop it from spinning. Now I was able to tighten the damper bolts with some force and didn't feel like the last time when I changed the opti. The crank spun easier. a4
Quick Reply: how to remove crank keyway
