Paxton SN93 Supercharger - What's needed?
Old 05-02-2013, 06:19 PM
ThoR294's Avatar
Default Paxton SN93 Supercharger - What's needed?
Long story short, father pulled out a SN93 blower for an LT1. If he has all the parts (piping, oil cooler, pulley, etc.), what else am I looking at to do to the car?
As far as I know:
Drilling the oil pan for the cooler lines
Tune
What about?:
Plugs
Injectors
Fuel Pump
Rebuilding the blower
Anything else?
Old 05-04-2013, 01:01 AM
ThoR294's Avatar
:-( no one?
Old 05-06-2013, 12:00 PM
ramair96ws6's Avatar
As far as I know:
Tune
What about?:
Plugs
Injectors
Fuel Pump
Anything else?
The pan is easy but you have to make sure you follow the instructions or you can hit the crank with the punch. If i had to do it again i would pull the pan and have an AN bung installed on it. If you dont it will leak.
Plugs one step colder than stock
42# injectors
Stock pump is fine to about 400-430 rwhp
Id have the blower inspected
Id call PCMforless and get a tune.
Old 05-06-2013, 07:12 PM
ThoR294's Avatar
Awesome man thank you for the info! Just replaced the pump with a stocker so that is good news. I am only going for ~6lbs, nothing crazy. I don't think these can go higher than that PSI anyway.
Old 05-06-2013, 08:19 PM
Evil Opti's Avatar
You going to be running an intercooler?
Old 05-06-2013, 10:43 PM
I would also buy an MSD BTM to take some timing out when you are on the street in hot weather with a heat soaked car I have one if you want it.
How man mile are on the car you are putting it on, please tell me it isn't that 96 in the sig
Old 05-07-2013, 12:57 PM
ThoR294's Avatar
~120k miles
It would go on the 96, if all goes as planned... lol is that a bad thing?
Probably not... I was told I don't have to
Old 05-07-2013, 06:31 PM
I would not do a blower. You would be much happier with a heads cam setup from the sale of the blower kit. 126K is a lot of miles and that bottom end wont be happy with boost. I would not run any blower on an LT1 car with out some type of air cooling liquid or intercooler.
Old 05-07-2013, 07:32 PM
ThoR294's Avatar
How much could I really get for my blower setup in that case? 6lbs would really slaughter my bottom end?
Old 05-08-2013, 10:18 AM
I have no idea without seeing the kit. you would have to provide pictures to get an idea. This is just the world according to me. I think you would be much happier heads cam then with a blower. I think if you hurt the motor with the blower you will be Sad
Old 05-09-2013, 07:20 AM
ThoR294's Avatar
haha I would. I do have a motor out of a 94 formula though....
My father is looking for the rest of the kit. As of right now it is on the drawing board.
Old 05-09-2013, 01:35 PM
BoostedDSM's Avatar
Everything I've seen these motors are good stock bottom end for 8 psi all day long without an issue. As long as supporting mods are there and a good tune you should be fine.
I'll be doing a procharged 383 at some point in the next year or 2 myself.
Old 05-09-2013, 02:24 PM
ringmaster72's Avatar
If you do not want to run an intercooler, you can do methanol injection for fairly cheap. The safest bet is to have intercooler and meth. I just put a procahrger on mine with intercoolers and meth with about 9psi. We will see how long it lasts lol.
Old 05-10-2013, 09:13 AM
Negative. Do a search you will see many motors let go with supporting mods. Go to camaroz28.com as well. These motors in stock form are a grenade with the pin pulled once you boost them.
OP belive what you may, but I have been in the LT1 work since 1998 and have had a hand in building some of the fastest most powerful LT1s while working at Combination Motorsports here in Las Vegas.
Old 05-10-2013, 11:22 AM
I agree, I know my motor is temporary, I am just hoping the intercooler and meth will let me live for a little longer anyway....
Old 05-10-2013, 11:38 AM
BoostedDSM's Avatar
I have searched actually, granted my 383 will be forged and all that fun stuff for boost. But I would not worry about running 6psi for a year or 2 if it was not a dd car. But you have to be pre pared for it to let go at some point or another too.
Old 05-10-2013, 05:14 PM
ThoR294's Avatar
I know anything over 0PSI can cause stuff to asplode... I have a 94 LT1 motor that can swapped in easily if necessary. I am just unsure of what I want to do. I was planning on LT headers/cam for my first real engine mod, but then my dad threw me this curve ball lol
Old 05-10-2013, 06:14 PM
BoostedDSM's Avatar
I'm going to put a cam in this motor before I swap over to my other setup, might sway me to just make a bigger cube n/a motor instead. A 396 sounds sooooo appealing lol. You could always just source everything for the kit and try it out, can't imagine it would hurt anything if you had it for a few thousand miles and pulled it back off.
Old 05-11-2013, 05:01 PM
ThoR294's Avatar
Boost just sounds like fun
Old 05-11-2013, 05:26 PM
BoostedDSM's Avatar
It does indeed, I miss my Turbo eclipse but I heard a lt1 firehawk in town that was procharged and that's what made me want to boost mine. Just so damn expensive to do it right.
Quick Reply: Paxton SN93 Supercharger - What's needed?
