lt1 custom sbc ps pump and alot more
so this year i made a sbc type 2 power steering pump conversion for my lt1 tt engine. im running a alternator conversion on the passanger side. redid my powder coating candy apple red. i painted the engine bay. and redid my interior so it fits over a wolfe mini tub. ( i had to modify the tubs) and i also made my own ls1 cluster. i got a new radiator and fans combo and new intercoolers. i also took out my upper core support and made it a bolt in. and my cold pipes are going over my radiator instead of under i jest got the engine back in and hopefulley have it running by this weekend. ill post pics but if you want to see something ill try and get a pic
here is more i cant get more to upload right now but the engine bay went the same color as the car purple pearl and the intake is the right picture and the powdercoat is a tri stage
yep. i ran about 28 psi on the street but i was blowing threw the converter at 65x rwhp on 14 psi and 24 psi no change. so i gave up last fall and i did a little clean up while i got a new converter. but it runs awesome. I'm actully going up some on the psi. and doing a new dyno in a couple weeks after i make sure all the bugs are out. and here is more of the interior.
This is a really well thought out and put together setup! Looks great and mean at the same time lol.What are your goals for this car if you don't mind me asking? Good luck with your progress and results!!
i need over 1000 rwhp. there are some big hp ls cars by me that i need to beat. but i think that its do able i think im going to be testing the lt1 block strength. last year i ran 28 psi. this year im bumping the psi up a lil.
