cam install no start
Old 06-16-2013, 01:47 AM
jsangster's Avatar
Default cam install no start
I install a cc 306 and rocker in my 93 z28 now my car wont start unless I pump the pedal and then it stalls out when I let off the pedal. I need help
Old 06-16-2013, 02:07 AM
AdsoYo's Avatar
Ensure spark plug wires are fully seated and in the proper location on the optispark.
Any check engine light/ trouble codes?
Old 06-16-2013, 03:01 AM
jsangster's Avatar
I did, i just put on new opti.
Old 06-16-2013, 03:06 AM
jsangster's Avatar
yes my check engine light been on since I deleted the egr but im not sure in any new codes. when I install the cam it started for about 30 seconds and it sputter out. I have checked the timing chain and the teeth matched up. will it start like that if one of the teeth are off?
Old 06-16-2013, 05:30 AM
Z28Camaro30Ann's Avatar
Did you have the PCM tuned at all or just throw in the cam and fire it up?
Old 06-16-2013, 03:22 PM
jsangster's Avatar
I just put it in and fired it up
Old 06-16-2013, 04:50 PM
squeekiejay's Avatar
check your grounds and throttle body and other gaskets and for vacuum leaks
look into the IAC Drill mod also
When I installed my cc503 it wouldnt run and idle till I drill the IAC hole a little bigger. then ran like a champ and ran even better after the tune.
and any other mods? stall? p&p intake/heads?
Old 06-16-2013, 05:34 PM
jsangster's Avatar
I have a 3600 stall. Headers. Magnaflow exhaust. I have a hyperte. Chip. I took one spark plug out to check the spark and the motor started
Old 06-16-2013, 05:41 PM
LT11996's Avatar
What year is your car? That hypertech "chip" isn't helping at all I'm sure.
Old 06-16-2013, 06:35 PM
jsangster's Avatar
93 z28
Old 06-16-2013, 07:31 PM
englundjd's Avatar
you need a tune! getting a tune will most likely solve your problem
PS that hypertech is a bunch of crap.
Old 06-16-2013, 07:52 PM
jsangster's Avatar
U feel a tune will fix the problem?
Old 06-16-2013, 08:23 PM
Village Troll
SS RRR's Avatar
A tune will not fix a no start problem. Regardless of cam the car should still start. May not idle well, but it will fire. You stated you ensured you had spark, how did you do that other than putting in a new opti? Did you pull a wire and see if there was spark? You make sure the opti harness is plugged in? Was the opti easy to slide onto the splined shaft or did you force it on? You can get the codes by jumping some terminals in the data port IIRC. There should be more info on www.shbox.com
How about the valves, how did you adjust them?
Old 06-16-2013, 09:01 PM
jsangster's Avatar
I pulled the plugs and check for spark. The car even started and idle ruff. But it ran. I didn't do anything to the valves
Old 06-16-2013, 09:24 PM
englundjd's Avatar
an easier way to put it, did you adjust your rockers? a lot of people refer to that by saying adjusting the valves because thats what occurs when adjusting the rockers.
Old 06-16-2013, 09:41 PM
td1168's Avatar
If your car starts and runs with you pushing the pedal but doesn't want to idle you need a tune. I've never heard of being able to swap in an aftermarket performance camshaft without reflashing the computer but I could be wrong.
Old 06-16-2013, 09:44 PM
Double check the lash on your rockers, get RID of the "chip" and get the PCM tuned, and I bet that will solve your problems and it will run great.
Old 06-16-2013, 11:00 PM
jewbacca's Avatar
I could be completely wrong but I thought that 93 was the only year that requires an eprom to be burned and installed on the PCM board. If that's the case he needs to look into a mail order tune where they can send him the chip. Again, could be totally wrong...
Old 06-16-2013, 11:51 PM
jsangster's Avatar
I got it running. I clean the throttle body of all that gunk and it crank and idle. Thanks for all you'll help. I been battling with this for weeks.
Old 06-16-2013, 11:55 PM
jsangster's Avatar
I felt so stupid
Quick Reply: cam install no start
