valve adjustment
#61
However, I did indeed e-mail Comp twice, as I had previously stated, and both times, they told me 1/8 turn past zero lash. The first time probably was to verify the 1/8 turn idea, as I was installing them for the first time, and the second time was probably after I had them installed, and noticed that they're a little "clicky", and I wanted to verify that the 1/8 turn I was initially told was correct. And yes, they are the Comp Rs....
And if anybody is interested in buying a set of Comp Rs, I'd like to sell mine. As far as I know, they're fine, just a little too noisy, IMHO, for a street engine. They have a couple thousand street miles on them.
#62
I recently bought a 01 t/a with a fresh top end build. Pushing close to 500hp. The build only has about 3k on it. Sounds like a the valve train my be getting a lil play in it so I'm wondering if I should have the valve adjusted soon since everything should be broke in by now. - Advanced Induction CNC'd 243s
- Advanced Induction custom grind...230/234 0.604/0.604
- ARP head studs
- Yella Terra 1.7 roller rockers
- FAST 102, Tony Mamo ported
- Fast 36 (42) lb. injectors
- NW 102 TB
- FTP 102mm lid
- ARP head studs
- NW 102 TB
- FTP 102mm lid
#63
Village Troll
