Engine build hp estimate
There are no Dynos within 100 miles of me...so does anyone know about what output this setup should make.....
Bored to 355
Cc503 cam
1.5rrs
Flow master cat back
Kn cold air intake
3k stall
Programmed computer
Bored to 355
Cc503 cam
1.5rrs
Kn cold air intake
3k stall
Programmed computer
335rwhp MAX
1 Post
... 285 flywheel vs rear wheel horse power. Do you want estimates on flywheel or rear wheel? While LT1's were usually under rated a bit, you weren't making 285 at the wheels stock. And in reality, depending on where your tune came from (handheld vs mail order), there could be a chance you didn't see a gain at all. Like bufmatmuslepants said, if it was a hand held expect around 270-280 at the wheels. If you got a proper mail order tune you could probably see around 300. If you get some real exhaust (long tubes and a cut out if you like the flowmaster sound) I would expect 330. Not sure why you went with 1.5 rockers. 1.6 would have benefited that cam a LOT more.
All numbers are rear wheel. Stock you may have had 230-240 rwhp since your auto, 270 is realistic possibly optimistic if you used a handheld tuner through an exhaust that flows less than stock on 1.5 rockers which make the 503 not that big on a rebuild with low compression pistons. If you have 12:1 compression, longtubes, a cutout, and a dyno tune you could be near 340, but based on your posts, ill stick with 270 rwhp, 320 flywheel.
1 Post
Jdawson, with proper bolt-ons (long tubes, cutout, CAI (which you have), and a solid tune) you can see as high as 290 at the wheels (if you're lucky). Add the 503 (which has seen great gains on stock heads, though with 1.6 rockers) and you could see some GREAT gains. I can't remember who, but I thought I read about a guy hitting 340-350 with the 503 (don't quote me on that though). Was there a particular reason you went with the 1.5's? If you're upgrading to RR I really don't know why you would opt for 1.5's. Plenty of people have seen great gains with stock cams switching to 1.6's.
1 Post
https://ls1tech.com/forums/lt1-lt4-m...ing-cc503.html
Brand stall will also make a big difference on RWHP through an auto as well. Some are terribly parasitic.
FWIW on my stock cube build with a 227int cam thats a bit bigger then the 503(plus 1.6s instead of 1.5s so it was even bigger then your 503/1.5rr setup), I only made 345 through a 3200 stall with ported heads and almost all supporting mods - thinner head gaskets, longtubes, 3" true duals, intake, valve springs, 1.6rrs, dyno tune, etc. Only HP mods I was missing was an EWP and UD pulley.
I don't see 330 on stock heads, auto, smaller cam, no longtubes, mail order...maybe 300-310 tops. Show me a 350 rwhp stock headed 503 car and I'll show you a happy dyno .
There are too many factors to consider so bitching over power estimates is pointless. Some cars make more and some make less, it's depends on how well your mods match up. Unfortunately, it doesn't sound like your setup is optimal for making the most power so I'd assume you're going to be disappointed.
Is your compression ratio stock or higher?
Install a full exhaust (Long tubes, ORY)
Ditch the Blowmaster for a real 3" catback
Upgrade to 1.6rr, more lift will help you
Do you have good valve springs?
Stock water pump or EWP?
How good is your tune? Is the knock module stock (because it could hurt you)?
Correct that stuff and you'll be in the 330 range
