Slick or Radial for M6 car?
Old 08-04-2013, 07:11 PM
HarleyZ28's Avatar
Default Slick or Radial for M6 car?
So I am currently running a M/T ET Street Radial. Best 60' is 1.9 on 15lbs of air.
I have noticed with these tires if you spin off the line its really hard to recover with them.
I have been doing some research and have been leaning towards a Hoosier slick c07 compound.
Can I get some opinions here from people who have ran both? Rear end is moser 12 bolt with 4:10 gears. Spohn lower control arms, body mounted torque arm, welded sfc's, panard bar. Stock shocks.
Old 08-04-2013, 07:46 PM
9-Second Club
Ed Wright's Avatar
You need bias ply slicks on a stick car. You need some initial wheel speed to be fast with a stick car. Bias tires recover much better from the initial turning the tires over than radials. Radial slicks don't recover well.
Old 08-04-2013, 08:48 PM
93M6Formula's Avatar
Bias Ply slicks for sure. A stick car needs to have tires that absorb the shock of when you dump the clutch.
I can't 60' on hard drag radials, they just spin.
Old 08-04-2013, 10:15 PM
Tom94TA's Avatar
Most everything I have read from searches on here to Mickey Thompson's web site say that with a manual trans bias ply tires work best. I just got a brand new set of M/T ET Steet bias ply slicks size 26-10.5-16. Let you know how they work after I get them to the track.
Old 08-04-2013, 10:37 PM
cardo0's Avatar
Well i didn't know u can find bias ply slicks in 16", i guess now i know - thx gupp. When i shopped for real slicks i found most were for the tire size i was looking for in 15". And from what i read lately a 15" rim won't fit over our brake calipers - but i haven't pulled a wheel yet to test fit a 15".
What i'm saying if u want to run 15" rims see if they fit first.
Hope this helps,
cardo
Old 08-04-2013, 11:12 PM
Tom94TA's Avatar
Cardo, the tires I got are DOT drag tires. Summit has them with free shipping and no add on FedEx oversize item charge like Jegs does.
http://www.summitracing.com/parts/mtt-3792
I picked up some 16" V6 steelies 'cause I didn't want to grind my calipers or spend a ton on the Billet Specialties 15 inchers that clear the rear brakes.
Old 08-05-2013, 12:58 AM
HarleyZ28's Avatar
I am running a 15x10 race star wheel on mine, had no brake clearence issues.
Old 08-05-2013, 07:38 AM
Hope this helps,
cardo
Hoosier Quick Time Pros are what a stick car needs and yes you can get them in a 16". LT1 brakes don't need clearance like LS1 brakes do on most 15" wheels. Infact a lot of LS1 guys swap to LT1 rear brakes to clear 15's.
Old 08-05-2013, 07:50 AM
Stroked96Bowtie's Avatar
28x10.5 and roll the fenders
Old 08-05-2013, 08:03 AM
9-Second Club
Ed Wright's Avatar
If your serious about going fast, and aren't wanting to drive them on the street, you need real bias ply Hoosier, Goodyear or MT slicks on 15" wheels.
Old 08-05-2013, 10:08 AM
Village Troll
SS RRR's Avatar
All of this. By going with a 16" wheel you are sacrificing more traction going with a shorter wall. Hoosier QTP's are what you need on a 15" wheel. There's not a whole lot to grinding the rear calipers either. Basically just the fins.
Old 08-08-2013, 03:14 PM
Fazz73jr's Avatar
Stock 15" iroc wheels fit with no grinding... yeah thats what im using for my slicks for now lol! Just had them laying around. I like the 15" v6 steel wheel idea tho ...
Old 08-08-2013, 11:27 PM
Tom94TA's Avatar
Default Bias Ply ET Street Track Results
Went to GLD tonight to try out my new 26-10.5-16 M/T ET Streets. Managed a PB of 1.81 60' at 13 psi, only suspension mod is lca relo brkts. These tires have fantastic grip without the driveline shock I got with my normal 17" radial tires. It's such a planted feel, you could get addicted to it. lol
Ran a 13.060 at 106.38, I need to fire the guy working the shifter!
Old 08-09-2013, 12:22 AM
garage_queen's Avatar
Why the need for slicks? Lots of people have had no trouble going 1.4-1.5, some even lower, on the MT 275/60/15 drag radials and the Goodyear DRs in the same size. Slicks are more forgiving, I agree with that, but is that only hiding a suspension problem or an incorrect launch RPM?
Old 08-09-2013, 10:09 AM
nitrous2fast's Avatar
The less shock saves a lot of wear on the clutch and all of the parts behind it. Besides the fact that slicks are being used on vehicles that are running 3.5 second quarter mile times. Maybe they are idiots and can't launch at the proper rpm??? Yeah, Radials much better.
Old 08-09-2013, 10:13 AM
9-Second Club
Ed Wright's Avatar
Are you insane?
Old 08-09-2013, 10:40 AM
Are you insane?
Maybe so, lol. Am I just reading wrong or am I hearing that doing any better than a 1.8 60' needs to be done on a slick. If you can't get your car to hook on a 275/60/15 MT DR you're doing something wrong....IMHO
Old 08-09-2013, 10:46 AM
I did not say that a DR does not have it's limits but it's been proven on cars upwards of 1500hp (yes, those are mostly autos). These guys are running sub 1.2 60' and 7 second passes.
Old 08-09-2013, 11:00 AM
9-Second Club
Ed Wright's Avatar
Stick racers that actually know what they are doing use bias tires.
Any damn thing will go under 1.8 in 60' if they have a clue what they are doing.
Most people know stick cars are fastest with some initial wheel speed, which (unless the car has totally no *****) radial will not recover ftrom that like a bias tire will. 1500 hp NHRA Pro Stock cars need that. About all automatic cars are quickest if they dead hook, unless your talking some of that "pro mod" stuff.
Quick Reply: Slick or Radial for M6 car?
