42lb injectors for heads/cam stock shortblock too big?
I'm picking up fek77s old 230/240 107.5 565/562 cam and either porting my own heads or picking up a ported set, compression wil be around 11.5-12:1 depending if I have the block decked, are 42s too big or should I get 30s? There's a set of 42s local to me for cheap.
Also, the ported set of heads I might get have 2.02/1.60 valves, how big is the valve relief in stock pistons? Will I have an issue?
Village Troll
There are arguments using too big of an injector can influence spray patterns and fuel will not atomize correctly. On that setup the max I would go is 36, but 30's would most likely be perfect. Are you having a shortblock built?
Here's pretty much my plan
https://ls1tech.com/forums/lt1-lt4-m...-opinions.html
But I'm gonna mill the heads 0.010 to get about 11.5:1, and possibly deck the block another 0.010 for 12:1.
I use 37lbs
