End of Season...11.0...figures!
Old 10-19-2013, 01:36 PM
Mystery Bird's Avatar
Default End of Season...11.0...figures!
Today was the last time I could make it to the track this season, ended up with an 11.09 @ 121. That's 1.1 tenths and 2.6 MPH better than this springs best. Close but no 10.9 like I wanted. DA was around 800. The MPH are there for a 10.9 but the car is just too heavy...
60 ft. 1.50
1/8 mph 96.54
1/8 et 7.03
1/4 et 11.09
1/4 mph 121.00
...or it's that damn truck transmission.
Old 10-19-2013, 02:31 PM
stevo9389's Avatar
it is that heavy ls1 nose. you should convert back to the LT1 style or get a sneaky pete.
Old 10-19-2013, 04:42 PM
Man-Crush Warning
Shownomercy's Avatar
80e is killing you for sure
Old 10-19-2013, 05:19 PM
You should throw yours in the trash now or you will be stuck in the 12's for ever.
Old 10-21-2013, 07:27 AM
Moderator
BizZzatch350's Avatar
Good Times! 3640lbs, you haven't pulled all that much weight out of that thing?
Old 10-21-2013, 07:38 AM
I did pull some this year but adding the roll bar, 4l80e, and 12 bolt put it right back in.
Old 10-21-2013, 08:38 PM
94zrag's Avatar
C'mon. One more attempt this saturday. It's supposed to be in the high 40* range. Just remove the front and rear bumper supports, and use my slicks and bias-plys. Those plus the colder weather and you have your 10.99.
Old 10-22-2013, 07:06 AM
I want to but have surgery on Thursday so I don't think I'll be able to drive by Sat. Pretty tempting though. Maybe I'll let you drive it for me.
Old 10-22-2013, 06:37 PM
94zrag's Avatar
Ha. I think my extra weight would offset the colder weather.
Good luck on thursday.
Old 10-23-2013, 01:57 PM
NewOrleansLT1's Avatar
What's the engine specs on that 381 if you don't mind sharing op?
Old 10-23-2013, 03:04 PM
381, Eagle forged crank, 5.7 rods, -6cc pistons, 11.3 compression, .050 quench, cleaned up TFS heads, Edlebrock intake, 1.6 NSA RR, 36lb FAST injectors, 242/248 on 110 LSA cam, shifting at 62-6300 RPM's.
Old 10-23-2013, 08:45 PM
Ever had it dynoed?
Old 10-24-2013, 03:26 PM
Originally Posted by NewOrleansLT1
Ever had it dynoed?
Nah, don't really care what it puts down for power. I'd rather be a track king than a dyno queen. lol
Old 10-24-2013, 03:33 PM
"MAC"'s Avatar
why not go bigger injectors and E85?
that should give you some extra hp to help get you into the 10.99
Old 10-24-2013, 05:05 PM
Man-Crush Warning
No E85 readily available in the tri state area.
Old 10-27-2013, 05:29 PM
Well, I was able to go back to the track again with the help of family and friends. Still didn't get the 10.9 but got another new PB. 11.01 @ 121.91. Was pretty happy none the less.
Old 10-28-2013, 01:02 PM
nitrous2fast's Avatar
a 200 shot would fix most of your issues.... just saying.
Old 10-28-2013, 02:41 PM
lol, or create new ones.
Old 10-29-2013, 01:46 AM
93Z2871805's Avatar
I think I would've ripped the passenger seat out and hit it one more time just for the number, lol. Car is flying for sure man, congrats on the new PB! Are you trying to go for numbers full weight, no A/C, what's the overall goal (obviously 10.XX, but under what parameters)?
Old 10-29-2013, 06:59 AM
All seats were removed for that run. Just hoping for a 10.9 slip NA, then maybe spray to a 9.9.
Quick Reply: End of Season...11.0...figures!
