built lt1 oil pump choice?
Old 01-24-2014, 08:42 PM
MoparChevZ28's Avatar
Default built lt1 oil pump choice?
What do you guys recommend for a fairly heavy breathing Lt for oil pumps and pans? Stock or HV pumps brands etc. What have you guys had good luck with. Also just bought some lunati lifters. Part # 72430. Will be ordering the 24x engine parts this week as well
Old 01-24-2014, 09:01 PM
9-Second Club
Ed Wright's Avatar
Please do not put a damn HV pump in it! There is no up side to keeping the valve covers full.
I like Moroso's std "blue printed" oil pump.
Personally, I use a reduced volume pump. ***-backwards from an HV. I'm only at 600 fwhp, but I have plenty of pump.
Simple deal is the blue printed Moroso pump. I use their pan too. Call Moroso about the correct part number. Mine is different because I no longer have a one piece rear main seal. Don't call a catalog sales guy, call Moroso for the part numbers. Then order from Jegs, or whoever.
It has a full length kick out & scraper. That pan is worth some power over the road race looking pan that is so popular here.
Old 01-24-2014, 10:03 PM
Thank you, I'll give moroso a call tomorrow if they're open. What is the purpose of running a low volume oil pump?
Old 01-24-2014, 10:06 PM
9-Second Club
Ed Wright's Avatar
Really don't think they will be open on Sunday. They can give you the correct pan & pump pickup numbers.
Low volume pump saves a few hp, and not having to bypass as much excess oil.
Old 01-24-2014, 10:19 PM
Man-Crush Warning
Shownomercy's Avatar
Can't really say whats in my motor oil pump wise, but its a canton pan, which fit fine and I use the heater element port for my turbo drain.
Old 01-24-2014, 10:29 PM
I think tomorrow is Saturday . Regardless, I doubt if they'll be open Lol. Gotchya thanks guys
Old 01-24-2014, 10:41 PM
9-Second Club
Ed Wright's Avatar
Whoops. LOL. Betting they aren't open Saturday either.
Wasn't going to name it, but Canton is the road race style pan I was talking about. Not made like any drag race pan I've ever seen. I personally do not like them. Had one, won't have two.
Old 01-25-2014, 07:37 AM
96capricemgr's Avatar
Oil pumps move more oil volume with more rpm, high rpm engines try and move so much volume they just go into bypass as Ed said without explaining, HV at high rpm can also go a step worse and besides being undo wear on the drive and HP consumption they can cavitate actually hurting oil flow quality to the bearings.
A Melling blueprint is a good choice for most builds but that said the stock pump is Melling and pretty darn good itself.
I think folks are too quick to worry about pan "upgrades" too, at 7500rpm+ like Ed turns his I am sure there is power in a pan designed for such, for the average street build I suspect the extra $300 would be better spent on the topend since most folks want to cheapout on that most critical part of the build.
Old 01-25-2014, 08:09 AM
Yeah I won't be spinning to 7500. Its a hyd raulic roller motor. It will probably see 6400 shifts quite frequently. My topend is pretty much done for now. Just need pushrods but I have to wait until my lifters one in to measure them.
Old 01-25-2014, 12:22 PM
9-Second Club
Ed Wright's Avatar
I still hope, for your sake, that Canton pan doesn't have an HV pump hiding inside. Can not imagine why they even sell them. Absolutely of no use. Not even circle track stuff. Been there too.
Old 01-25-2014, 01:08 PM
FormulaJoe's Avatar
I've got the melling high pressure, reg. volume and I pretty much wish I just went with std. pressure and volume... Sits at about 75psi at cold idle and any rpms above idle bring it up quickly to around 90. Until oil warms up that is, hot idle it's at about 35psi (IIRC, been a few months).
Old 01-25-2014, 01:56 PM
96TransAmboosted's Avatar
I run a melling pump and have always had great oil pressure with a canton road race pan.
Old 01-25-2014, 01:58 PM
BALLSS's Avatar
FWIW, this link to Melling explains what HV oil pumps are
http://www.mellingselectperformance....lume-pumps.pdf
Often they are used in motors with wider than stock bearing clearances, and/or external oil coolers and/or filter. I would not use one in a motor with standard bearing clearances.
"Higher Volume" is not the same as "High Pressure" oil pumps
Old 01-25-2014, 03:07 PM
9-Second Club
Ed Wright's Avatar
Wide bearing clearances are just dumb, but I guess some guys just don't know any better. Not sure what they would be trying to accomplish. One thousandths per inch crank journal diameter is commonly used. Most of my cranks use the old 283" journal sizes with spacer mains and rods made for them. Last couple have used what guys call "Honda rod bearings", which are 1.88" diameter rod journals. 283" rods are 2", versus LT1's 2.1" diameter. Newest deal is "BMW rods ", which I think are 1.78"? Not exactly sure about that number. Manley makes rods for both.
And 75 to 90 psi? Why? 60 psi is more than enough. High oil pressure is a power waster, oil temp increaser, also in a SBC a cam gear/driven gear wear inducer. GM says ten psi per 1000 RPM, and that is WAY safe & covering their asses dummy proof.
My low volume pump has the spring clipped for 45 psi. Seldom sees over 8500 RPM.
Old 01-25-2014, 03:43 PM
BALLSS's Avatar
Ed
You certainly know your stuff and I am not advocating HV pumps have a universal use. With standard bearing clearances a standard pump is best. Some have swapped springs to increase pressure.
Some of the HV pumps are "standard" pressure. They just flow more "volume" of oil. My understanding is some builders use slightly wider bearing clearances and HV pumps, often with thicker oil like 10-40 or 20-50, to provide a thicker oil barrier between bearing and rod/crank. I know the Porsche 911 flat 6 spec 20-50 as factory fill due to wider clearances
Companies like Melling feel there is a need/use which is why they make them and there seem to be many aftermarket engines using them. I think “problems” like worn cam drive gears that are attributed to using a HV pump is when one was used with standard bearing clearances or cam gears that are wiped due to new cams with gears that are billet or not properly lined up with the drive gear
I have one in a 383 (builder spec the HV pump) and after 30k mi there is no wear on the stock 120k mi cam drive gear so for me at least it has not been a problem in that area. Oil pressure is 45 at idle and increases to 60 max when I hit 6k+ RPM’s. I also have an external oil cooler (air, not radiator) but had that on the car with the stock motor/pump
Old 01-25-2014, 04:32 PM
FormulaJoe's Avatar
75 just after start up when it is idling... Drops to 35-40ish at idle after about 10 minutes of driving conservatively. Warmed up shifting at 7k WOT it's around 70 psi. I'm not slamming through the gears redlining with cold oil at 90psi, but when the engine is still warming up and I'm cruising just shifting at about 3k the pressure gets up there... I know about the cons of too high oil pressure. I didn't think it would be so high when I was getting the pump lol... Perhaps I'll swap springs out sometime, but warm psi is great. So I don't have much concern really...
Old 01-25-2014, 07:24 PM
bowtienut's Avatar
There is no such thing as a high volume pump that is "standard pressure".
We're talking positive displacement pumps; a high volume pump is moving more oil; if it's moving more oil through the same oil passages, the pressure at any point is higher, period!
That Melling link provided has a lot of BS in it, parts of it completely misleading, written by somebody that doesn't understand the subject. Melling should be embarrassed to have published that.
Old 01-25-2014, 10:59 PM
flyinZ's Avatar
I like to read threads like this. Lots of good experience/info in this one.
Old 01-26-2014, 11:43 AM
Big Al's Avatar
The pump maximum pressure is set by the bypass spring and valve in the pump. So you are wrong. The high volume pump is only useful if you have large clearances that would allow more oil to "leak" than a standard volume pump could supply. Or if you like to brag about how much oil pressure you have at idle
Al
Old 01-26-2014, 01:15 PM
What bowtienut is saying is that at a given rpm/bearing clearance a HV pump will create higher pressure. It will also simply go into bypass at a lower rpm and is more likely to cavitate, and MUCH MUCH more likely to prematurely wear out the drive. I assure you he has a much better understanding of mechanical workings than the vast majority of us.
Far as the HV needed for wide clearances, a lot of shops use wide clearances in place of build quality. The wider the average clearance the less likely sloppiness or an unmeasured clearance is to be too tight. We see this kind of thing done by shops that do halfassed things like assembling a shortblock with airtools cross threading a rod bolt etc.
I am sure there can be a reasonable argument made for loose clearances on a high hp motor, but on the normal 400-550fwhp LT1 not much reasonable argument to be made.
Quick Reply: built lt1 oil pump choice?
