how will it run? with cam? please
96 trans am has frash lt1 with 10.6 to 1 cr ,cc305 cam, stock stall, stock manifolds , 3.42,ram air system off ws6 car, no cats and cat back flowmaster and dr. what will it run like in 1/4? I plan on getting lts, ory and 3200 stall
13.3 @105
Why would you go to the effort to build the motor without headers and then ask for advice how it will run? Rather then get flamed why not just buy headers and then ask for our opinion. Id say when all said and done it could likely be mid to high 12 sec car if setup properly.
and want to make sure this one holds up..
well I just built the motor.. its third motor in a lil over yr.. last two I bought put in didn't make it long.. one made it 4k miles spun rod .. other made it 600 miles put a rod though oil pan.. going down the high way 65 mph.. so done this one right built motor myself and running a lil low on money after ..
yea one was from a salvage yard.. my brother works for.. when I got car it didn't have a motor and car was give to me.. so I got a deal on motor.. tried it.. failed.. let car set seven months.. my dad give me a motor out a car he had bought.. it run good but car was a hack job.. so wouldn't stay running.. I been fighting with my self over putting money in this car or in my ls1 Camaro.. ls1 runs great but its at 190k so its on borrowed time..
You are definitely choking that thing. I wouldn't worry about the cam you can make decent power out of the cc503 with the right setup. Get some nice LT's and a decent stall on it and it will be a night and day improvement.
Use it. Just want it run good
They are pretty similar. 503 has more intake duration and slightly less lift. 503 should make a little more power but not significant.
CCA-07-305 --- 220@ .510/ 230@ .510 (1.5RR)--- 114 LSA --- 1500-5500
CCA-07-503 --- 224@ .503/ 230@ .510 (1.5RR)--- 112 LSA --- 1800-5800
Less intake duration and a wider LSA. It's pretty much as mild as a hotcam. The 503 still has an edge on it but you should go even bigger than that because you have an A4. I went with a 503 in my car because I have to deal with cam surge in gear with the M6. You don't have to worry about that if you have a decent sized stall because the trans is doing all of the work for you. I think the 306 would be more suited.
after looking around with stock heads.. I see the cc305 running about the same number as the cc503.. 108-114.. why everyone think the 503 is so much better but I cant find the big deal?
