Pro comp rockers?
Pro comp rockers?
Im using some pro comp rockers. Any feed back on that brand of rockers? I was reading on other forums and not to many good things said about them. Any help would be appreciated. What brand do you guys recommend?
Howards
Harland Sharp
Crane Golds
Comp Cam Golds
Im assuming a 7/16 stud is being used and you want full roller? I like the Howards Purple Billet Alumin Rockers for the Price, you cant go wrong. They are American Made with a lifetime warranty and rated to 900lbs of spring pressure/.900 lift.
Something like that you cant go wrong with any of the major companies:
Howards
Harland Sharp
Crane Golds
Comp Cam Golds
Howards
Harland Sharp
Crane Golds
Comp Cam Golds
I've been using Comp Cams Magnum steel arms for quite a while, and never had a failure. I use a 7/16" stud, and I use a stud girdle.
Another American company is coming out with some quality stuff - Scorpion. I'm using their valves, but haven't taken the engine apart to see how they're doing.
Pro-Comp is cheap off shore copies of American products. I don't use anything from them. Never buy cheap parts, they're too expensive.
