Car falling on its face and dying
Old 05-07-2014, 06:47 PM
Wallj's Avatar
Default Car falling on its face and dying
So recently my car has been acting up. I start it, idles rough, and if I give it any sort of gas it wants to die and has black smoke coming out. While driving, it has serious misses at random rpm. Checked the ignition coil and it's good. I have a fuel pressure gauge in a pod. And the pressure reads good. I'm pretty sure my plugs are getting spark too. Is it my opti? I thought that those just die all at once. Any suggestions?
Old 05-07-2014, 06:59 PM
bfd811's Avatar
Sounds like an opti to me. If you take it out check the rotor side of the distributor. The rotor screws couldve come loose
Old 05-07-2014, 07:21 PM
im-not-guilty's Avatar
Any codes ????
What's the temp sensor reading on the scan tool
Old 05-07-2014, 07:56 PM
Wallj's Avatar
When this first happened, I got a check engine light but the car was at home and I didn't want to risk going to autozone to get scanned. I probably wouldn't have made it. So I unhooked the battery overnight to let everything reset and restarted it today and had the same symptoms but no SES light.
Old 05-07-2014, 10:42 PM
bfd811's Avatar
Okay step one is gonna be finding out what that code is. Thats gonna help you the most in finding out what direction to take your second step. If its a misfire code then its more than likely going to be an ignition problem. The fact that you said black smoke is coming out of the exhaust and that your reading good fuel pressure makes me think its probably not a fuel problem but perhaps an overfuel problem. Check that code and post up what it says. Sounds like a sensor to me. O2, Coolant temp, Throttle position...maybe one of those
Old 05-08-2014, 07:08 AM
Village Troll
SS RRR's Avatar
Possibly a loose rotor on the optispark.
Old 05-08-2014, 01:26 PM
Wallj's Avatar
One thing to add that just came to my mind. Right before this happened, I broke the black outline or guide or whatever you call it that the coolant sensor plugs into. The one going into the water pump. I epoxied that piece back on and then plugged the wires in. Maybe a bad connection here could be causing the issues?
Old 05-08-2014, 01:31 PM
Village Troll
SS RRR's Avatar
It could very well be. That is the sensor that feeds the PCM information. The sensor in the head is just for the temp gauge.
Old 05-08-2014, 08:09 PM
bfd811's Avatar
Sounds like a likely culprit to me. Slap a new one in and let us know how it works out. I think they're relatively cheap $<20. Just like SS was saying this is the important temp sensor. It feeds the PCM a temp reading and the PCM fuels the car accordingly just like on a carbureted engine where it uses a choke to limit air so it can get more fuel on a cold start up the PCM in a fuel injected car does this using the temp sensor and spraying more fuel through the injectors when it senses its cold. So if your temp sensor fails it can act in a similar way a carbureted car would with the choke stuck closed.
Old 05-13-2014, 11:59 AM
Wallj's Avatar
Just figured I'd update this thread. It ended up being that sensor. I went ahead and bought the new sensor and a new pigtail, installed them both, and she runs great! Crazy how one little sensor can wreak havoc like that. Thanks for all of your help!
Quick Reply: Car falling on its face and dying
