Help Please, in middle of project! Bell housing wont serperate
Old 05-28-2014, 08:25 PM
firefighter34's Avatar
Default Help Please, in middle of project! Bell housing wont serperate
So I pulled my 95 LT1 M6 motor and trani from my car. we are trying to separating the fly wheel housing from the block but it wont come all the way off. It's like an inch clear of the block but is binding on something. It's like the throwout bearing is bound?
Help please, have to get this motor back in tomorrow!!
Old 05-28-2014, 08:32 PM
Village Troll
SS RRR's Avatar
Is the trans still attached to the bellhousing? If so you must pull on the shift fork to separate it from the t/o bearing. After that it should come right off if all the bolts are off.
Old 05-28-2014, 08:54 PM
yes the trans is attached to the bell housing, we will try that! Thanks
Old 05-28-2014, 09:10 PM
No didn't work...
Old 05-28-2014, 09:36 PM
shbox's Avatar
Every time I read a post like this, the clutch fork has not been released from the throwout bearing like SS RRR mentioned.
Old 05-28-2014, 09:42 PM
LT1FirebirdSLP's Avatar
You might have to push the trans back in a bit to get the fork all the way off the TOB. If you tried removing the fork with it partially separated it might still be binding a bit.
Unless you grenaded something in the clutch causing the two to somehow be locked/fused together.
Old 05-28-2014, 11:09 PM
Thanks Guys! Are you saying to remove the fork? like pull it out of the bell housing?
Old 05-29-2014, 12:17 AM
guppymech's Avatar
The clutch fork is held captive on the Tee it pivots on by a spring clip riveted to the fork. Pull the clutch fork outward away from the throwout bearing, it will move about 1 inch then you'll be able to remove the trans.
In the lower picture the fork is disengaged from the Tee and it's mount bolt.
Old 05-29-2014, 05:36 AM
bufmatmuslepants's Avatar
Great post guppy, he is spot on.
Old 05-29-2014, 10:26 AM
Awesome! thanks!!
Old 05-29-2014, 12:21 PM
Village Troll
SS RRR's Avatar
Yeah sorry, should've been more clear. That should do it though.
Quick Reply: Help Please, in middle of project! Bell housing wont serperate
