P0400 code, EGR pressure sensor?
Old 11-18-2014, 08:03 AM
ErikEverhard's Avatar
Default P0400 code, EGR pressure sensor?
Guys just had a rebuilt motor installed in my 97 z. Runs strong and great but it is showing the code P0400, and I need to get the car inspected. Autozone told me that it needs the EGR pressure sensor. I do not want to keep spending money on this , so do you guys think that the pressure sensor is it?
The car does idle high sometime 1500 rpm
Old 11-18-2014, 09:20 AM
shbox's Avatar
I doubt it, since there is no such thing. Perhaps your EGR valve is not working. High idle might be a vacuum leak. Post more details about your car and mods.
Old 11-18-2014, 08:03 PM
Just had a new rebuilt engine put in the car. All stock, and basically everything under the hood is new. Water pump, plus, wires, thermostat, temperature sensors, fuel pump, clutch. Like I said car runs great to me, I just need to get that light off so I can get it inspected.
Old 11-21-2014, 07:51 AM
mab6680's Avatar
is the vacuum line hooked up to the egr?
Quick Reply: P0400 code, EGR pressure sensor?
