396 LT1 Short Block for Sale
AS PREVIOUSLY POSTED:
396 LT1 Short Block For sale with about 3000 miles on it.
$3000 plus shipping or local pickup from Putnam, CT.
-Bored .30 over
-3.875 Forged Eagle Crank
-Splayed 4 bolt main caps
-6" Eagle Rods
-SRP Forged Aluminum Flat top pistons with 5cc valve relief part # 144995
-Hastings rings
-Comes with Heavy duty Timing chain, lifters, newer Opti, Timing cover, and new oil pan, and camshaft (see cam specs below).
-DOES NOT COME WITH ATI SUPER DAMPER
Cam Specs:
-Custom Grind Cam Comp Cams
-248/254 duration @ .50
-.375/.387 lobe lift
-110LSA
-I used AFR 210 55cc heads that used rocker ratios of 1.6 intake and 1.52 on the exhaust and lift is .600/.588 respectively.
Pictures below reflect each individual cylinder fyi.
*Note the pistons were clearanced professionally by Golen Engines in NH for clearance on the larger valves that were on the AFR 210CC heads, if you plan on using heads with larger valves at the least the clearancing is already done!
Pretty good deal if someone is looking for a budget built with quality forged parts that is slap on ready to go.
-Bored .30 over
-6" Eagle Rods
-Hastings rings
Cam Specs:
-110LSA
