Lt1 1992 Silverado
Lt1 1992 Silverado
I have a 1992 Chevrolet Silverado with a summit crate 350 in it but it's blown so I'm buying a new motor and I found a lt1 out of a 93 vette. I have a 700r4 tranny and I would like to know if I buy the lt1 would it go in my truck just fine or would I need anything special? I'm not the best mechanic and are unfamiliar with alot of stuff but I just want to know if I need anything different to make the lt1 fit. Thanks!
It will bolt right up but you do realize you need the wiring harness to make it run right? Unless you're going carb, but it's hard to find the GMPP intake for these any more.
9-Second Club
Harnesses are easy to find. You will need a '93 F body LT1 computer also. The VATS (anti-theft) will need shut off in the chip. I would find one at a salvage instead of buying a re manufactured computer. New ones are no longer available, nor are the factory "chips". Get one at a salvage, and it will have the chip (MEMCAL is the proper name for it) which can be erased, and reprogrammed for no VATS, a 700R4, and any emissions delete you may need.
That's MISTER MODERATOR
A question for the OP: Is the blown 350 in this truck still running on the factory TBI system?
If yes, using the carb intake on the LT1 engine allows using the stock TBI (you'll need an adapter) and HEI distributor.
You'd need to remove the optispark and block of the hole at the cam for it and retain the LT1 water pump (as the LT1 is reverse-cooling, a good advantage).
The TBI ECM would still work well as it's still a 350.
PS
The only injector difference I know about is the change from batch to sequential, and that would be handled by the 94 engine harness.
9-Second Club
If the ECM for the 1993 Camaro is as hard to find as unreliable as the ECM for the 1993 Corvette then it should be avoided. As for the optispark IIRC you can change the wire harness to the 94-95 style and it will work. With no electronic control on an automatic I understand you could program the 94PCM to manual, and it will work.
PS
PS
The LT1 swap is a great way to get good reliable power when done properly. The whole purpose is to take advantage of the fuel injection. Any deviation will reflect in performance and reliability IMO. I would advise having the engine, harness and ecm from the same car.
The injector flow rate is different. That would require more tuning. Programmed for a manual transmission does not control the TCC very well. Millions of '93 LT1 cars running around with zero ECM problems. Doesn't sound like your business, whatever it may be, doesn't deal with a whole lot of engine swaps. I work with street rod shops all over the country. 1994 PCMs with 1993 LT1 engines and 700R4 trans is not how anybody I work with does it. Of course, you may know more than the pros who do this every day.
Well seeing as LS1tech.com is not for the general public i guess I'll leave you and your condescending attitude alone along with LS1tech.
I was unaware that ls1tech.com was only for businesses. Millions eh? How many 1993 Firebird Formulas, Trans Ams, Camaros, and Corvettes were made? I don't know but I doubt millions.
