Have an urgent injector question..
So I just did a CC503 recently and had used a set of 24lb LT1 injectors since the stockers are 22lb on my car. They were working fine for awhile until yesterday. The car's been sitting for 3 weeks and yesterday I started it and drove it and it was a complete dog. Felt like it was running on only 6 cylinders and making a lean popping sound when I let off the gas. I assume an injector or two is stuck and causing this.(Just a guess) These injectors were sitting for a few years before I put them in so i'm sure that didn't help...
Anyway... I want to swap in a set of stock LS1 injectors mostly for testing purposes and see if runs better. They are from my buddies '99 Formula and he just pulled them last week from his running car with only 60K on them so I know they're good. I understand these should basically be 24lb injectors on LT1 fuel pressure so I should be fine correct? Any reason I can't do this?
For testing, why don't you just pull the fuel rail and see if they are all spraying?
I thought about pulling the rail to test but that just sounds like a real mess. I don't want fuel spraying all over the motor.
I'm pretty sure they are minus a little modification to the holding clip. I guess I was just wondering if they are okay with my current tune. It's tuned for 24s which is basically what LS1 injectors are, at 43.5PSI as far as I know.
I got another question...
If I were to take an infrared thermometer to each header primary, would the hottest one point to a lean condition on that cylinder? Or is that not right.
Might want to make sure none of your plug wires are not arcing on your headers. My car was running fine and then one time I took it out and it was running kind of like you described. After troubleshooting a whole bunch of things I finally traced it back to a plug wire touching the manifold. I have no idea how that happened because back then the car was basically stock and still had manifolds.
Now I know that's not good for one thing, but I just want to confirm with you guys. I assume that the blue sparks is energy escaping the wires and not giving full power to the plugs which is causing my loss in power with any amount of throttle? It idles smooth and isn't missfiring but it's has no power whatsoever. Also it now smells pig rich and I can't even stand near the car without getting watery eyes.
I'm guessing your wires are toast if there is any sparking going on. It sucks spending more money, but maybe get the arcing issue solved and see if it is still running bad.
I put these sleeves on my wires and they are 100% great.
Amazon.com: DEI 010542 Brown Titanium Protect-A-Boot Spark Plug Boot Protector: Automotive
I just ran a new set of AC Delco wires in the stock locations. I think there is a lot less chance of the wires getting burnt that way. The only thing you really have to protect is the boots near the headers if you have everything secured good.
