LT1 PCV Valve?
LT1 PCV Valve?
I have a 94 6 speed Corvette with a remote mount turbo setup with 10 lbs of boost and i am noticing that when I come off boost I am getting a little bit of blow by and it seems like some oil is coming out of the dipstick. I have a stock PCV valve and i have tried a one way check valve however the check valve just seemed to make things worse. What should I do to fix this?
No intercooler the turbo is remote mounted so the distance of the charge pipe sort of acts like an intercooler... I do plan on a meth kit in the very near future I just need this bug ironed out and i need a new scavenge pump as well
If you remove your oil fill cap and see much smoke puffing out, it might indicate a more serious mechanical problem. Do hope it's not this, but investigate the cause of the blowby and see if you got any cylinders not making cranking or low rpm compression.
You can do a simple cranking test with the coil wire grounded and see if it is even or uneven. Uneven indicates low compression in one or more cylinder. Then do the leakdown tests if you can access the spark plug holes.
On the last run ever with my stock engine, my car still went 12.4 with a blown head gasket and these pistons. So they will still make power with the ring lands cracked.
Did you do the cranking test that I suggested?
Regarding your comment on the length of pipe acting as an intercooler, I don't agree. With 10lbs of boost, you need to cool the intake charge. Def get an intercooler and/or meth. You are on borrowed time with a stock shortblock.
You need more crank evac but as mentioned, you may have a mechanical issue. The pressure needs somewhere to go and since you have a closed system, it will head for the dipstick or out of the engine seals. I run a MM pcv can with one breather on the VC. No issues.
MightMouse catch can. PCV valve is removed from intake, tube goes to dirty side of can. From the can with the PCV/check valve, a line runs to the port below the throttle body. Once valve cover has an open breather, other is closed.
I don't have a pic handle but will take one when I am back home.
