Built LT1 drag car
Old 06-22-2015, 11:28 PM
nx_black97's Avatar
Default Built LT1 drag car
Finally getting some seat time after months and months of thrashing on this car still got some tweaking to do at the track and also need a new battery last pass i made last weekend it turned off on me. I know my car will pick up some from battery because I'm running msd box and also running coils instead of opti spark. Here is a video of the car
it spun off the line and was out of the grove till after 60ft. I also didnt leave on transbrake just left on footbrake. Car still ran a low 7 sec pass. I made one more pass and the car lett hard wheels up leaving on 2 step and then battery died after 300ft and i still picked up a full second at 330ft mark coasting. Hopefully be able to make another trip to track to get good accurate timing. MAKE SURE YOU WATCH IN HD!!!!
Old 06-23-2015, 06:19 AM
joelster's Avatar
Looks good!
Old 06-23-2015, 08:59 AM
nx_black97's Avatar
Originally Posted by joelster
Looks good!
thanks!
Old 06-23-2015, 09:29 AM
NewOrleansLT1's Avatar
What's all done to it bro?
Old 06-23-2015, 09:58 AM
transbird95's Avatar
Yes tell us more! Pics also!
Old 06-23-2015, 10:39 AM
azmarkus's Avatar
What he said, details and pics of inside, outside, engine bay, etc.
Old 06-23-2015, 10:45 AM
sweetbmxrider's Avatar
Was that 1/8th mile?
Old 06-23-2015, 11:42 AM
MonmouthCtyLS7's Avatar
What's the setup?
Old 06-23-2015, 01:36 PM
Puck's Avatar
Did you fill in the holes on your roof after pulling the headliner, or do newer years just not have them? That "I" beam support on the roof is nice and smooth on yours. I pulled the headliner on my 93 and was pissed that there are big holes underneath it in the bracing...I wanted to just paint the roof black instead of dealing with the headliner but it will look too ghetto with all the holes lol. Will probably just cover it in vinyl instead now.
Old 06-23-2015, 04:57 PM
nx_black97's Avatar
A whole lot of crap is done to it but its a built small block on setup to run 2 kits. trick flow 197cc heads with Pacaloy 943 Endurance SR valve springs w/Xceledyne ltwt ti-17 retainers & locks + hardened machined locators
> Competition plus ferrea 21-4n stainless valves 2.08I/1.60E w/ hp metal clad Viton seals
> 100% cnc'ed intake/exhaust runners & chambers
> Newen cnc'ed f1 quality valve job microns tir
> Bronze guides hand honed to competition clearances & tolerances
> Deck is pcd milled to insure flatness/finish & achieve desired chamber volume of 60cc
> Hand de-burred to remove all sharp edges
> Jesel sportsman shaft mount rockers
> Morel 4604 lt1 solid lifters w/tiebars
> Ai one piece .375 dia hardened 4130cm pushrods .080 wall
> Intake lt4 cnc ported to match heads and achieve desired flow numbers
Heads alone were almost 5 grand.
th400 rev valve body transmission FTI 3800 stall 12 bolt moser 33 gun drilled axles and 3:90 gear Strange spool.
Full PA racing K member and sphon torque arm and anti roll bar
There is literally so much stuff done to the car i could keep going but i figured people would want to know head work the most. If someone tells me how to post pics I will gladly post some pics of the car.
Old 06-23-2015, 09:19 PM
Solid roller cam? Or?
Old 06-23-2015, 09:41 PM
nx_black97's Avatar
Custom cut 8620
Intake centerline 104.5 tappet lift .438 rocker arm ratio 1.6 valve lift .700 Exhaust centerline 112.2 tappet lift .429 rocker arm ratio 1.6 valve lift .687
Old 06-24-2015, 03:45 AM
allhenyia's Avatar
Old 06-24-2015, 07:55 AM
nx_black97's Avatar
Cage is just installed not painted yet. Will be painted.
Line lock on the steering wheel and trans brake on shifter. Moroso switch panel with led
At the drag strip
Me changing tune up in car
Pushed back right here when we found out it has a dead battery lol not always a good feeling when you have to be pushed back but luckily an easy fix
Old 06-24-2015, 07:57 AM
Village Troll
SS RRR's Avatar
Because you have the factory steering wheel does the car still have air bags?
Old 06-24-2015, 08:04 AM
Man-Crush Warning
Shownomercy's Avatar
Low 7s 1/4 car?
Or 1/8?
Whats it trap?
Old 06-24-2015, 08:29 AM
nx_black97's Avatar
No the car does not have air bags
& the car suppose to run 7.00 maybe high 6s on motor according to guy i bought it from but we have changed a ton since we bought it (roll cage(which is now chrome moly not mild steel and that will change weight a lot), scatter shield flywheel shield, longer studs, seat belts, had to cut up fender wheels for the tires, took about 15 pounds of extra nitrous and fuel lines out and ran them the proper way....etc.) so haven't got accurate time completely yet hope to go to the track this weekend and see what it will do but it ran 7.20 spinning horribly at 60 ft and like i said the last past i made last weekend it hooked and did a wheelie and then cut off on me a little after 60ft due to dead battery wasn't enough voltage to run msd box blah blah blah.
Old 06-24-2015, 08:38 AM
I may have missed it but what does the car wiegh?
Old 06-24-2015, 08:45 AM
Man-Crush Warning
1/8 or 1/4....?
Old 06-24-2015, 08:53 AM
nx_black97's Avatar
1/8th mile & i haven't weighed it since new cage but I'm guessing 3250 with me in it i only weigh 150 but I'm not completely sure i have someone who has scales just haven't weighed it yet.
Quick Reply: Built LT1 drag car
