parts question eletric water pump
Who's running csr or meziere? I have a 355 I'm finishing up. Just wanting to know if csr is worth 180 or so? Cause I don't want to, but I will drop the 300 on meziere. Thanks guys
here are the 3 arguments you can expect to read in this thread and the countless others like it:
1. brand 'x' is worse than brand 'y' because I had a bad experience with brand 'x' but brand 'y' has given me no problems
2. STFU n00b y u need electric water pump when mechanical pwns all!
3. tons of bitching back and forth brand 'x' vs. 'y' vs. mechanical
In my experience: The Meziere seems to operate more quietly than the CSR. I have listened to several other cars who have run both (including my own) and the CSR is always slightly louder. There was no consistent performance or reliability difference, just cost.
...don't let hrcslam get word of this new electric WP themed thread, or a spirited debate will ensue! :https://ls1tech.com/forums/lt1-lt4-m...ng-solved.html
It's sad that as soon as I saw this thread I knew you guys would do this. Like Children. It's also sad that EWP users are STILL dragging this out. Again, it was the EWP guys going into the EWP vs MWP debate? Why?
Man-Crush Warning
I run a Meziere HD and have had no issues with it as of yet.
Basically, are you running any timing set other than stock or the LT4 HD? If so, you can't run a MWP, so moot point.
Are you running a large displacement, high SCR, ragged edge NA motor in a road race setting? If not, the "need" for a MWP is moot.
Are you good at wiring and or have some intelligence? If so, wire up a EWP and call it a day.
Confused?
Cause this dumb *** ls1tech, and its a sub forum for a car that is selling for under 3k these days. Its all downhill from here.
Confused?
Confused?
I agree a stock motor or close to it shouldn't have much issue with an EWP for most driving styles and locations. But ambient conditions make a big difference in the cooling capacity of the system.
I'm not going to tell someone who wants to run an EWP not to, unlike some EWP users have to me.
I was going to leave this alone. But, let's be real here. How many EWP threads have been bombarded by those that prefer a mechanical? None. How many mechanical threads are bombarded by the EWP guys? Seems like ALL of them. You have your demographic definitions confused. Let's be clear on this AGAIN, I have no personal problems with EWP's, they have their place. But, I'm not going to IGNORE the facts and physics to how they free up horsepower either.
Let's make this MORE obvious for you. In MY thread I gave advice on a fix for our old high mileage MWP spline couplers, someone else (EWP guy BTW) came in and started the debate (as most MWP threads go). Here, the OP asked which EWP to use (not EWP vs MWP), other users (EWP guys again) brought up the MWP debate and my name. I defended ME. You were saying??
