Ok so now what?
Ok so now what?
My machinist want my gear ratio and tire size. What do I tell him? My rear end is going to be s60 with 3:73's (because I have a 93) and my transmission is staying in I'm just buying a kit for it.
Oh lol I thought he was saying like my rim size lol sorry dude thought you were cracking a joke, how do I determine my gear ratio? He said he want to make sure my setup will work?? I don't think he realizes I just want him to do the work and install what I bring him?? You guys are building this car, I'm just taking advice and applying it haha
Village Troll
So I take it the machinist is going to install the cam? What's the cam profile?
Good reference: www.f-body.org/gears
1. Tell your machinist that your going with 26" tires and 3.73 gears and install your f'ing parts;
2. Tell the machinist to mind his damn business and install your f'ing parts;
3. Take the car elsewhere.
Personally, if he can't just do the work I hired him to do, I'd do a combination of #'s 2 and 3. But then.....I'm just a hostile, pushy SOB .
KW
Village Troll
Can you say what your cam profile is going to be or is it super secret? No one can really tell you what gears/stall to run without that info.
Edit- One more thing. You need to establish a good relationship with your builder. Being a douchebag to your builder by telling him his questions aren't any of his business won't get you anywhere. You establish a relatoinship with your builder means the possibility of more care being exercised with the building of your engine. You start being a dick then why should he care whether or not your **** blows up minutes after it is ran...
He could be asking because he might be trying to select a cam for you based on speed across the traps expected. If he's not picking the cam, or building your trans, picking your stall, installing your gears, then tell him super swamped 44s and 2 1/2 ton axles, he wil go what? And you go what does it matter, here's a beer.
243/251 .597/603 110 LSA cam for "built" 383 with -5 cc flat top pistons and 6800 RPM shift RPM
FULLY PORTED 21* TFS heads with upgraded 2.055/1.60 valves, dbl springs, 7/16 studs, guide plates
That is the setup I am getting from Lloyd
So when I order the rotating assembly and drop it off to him and he bores the block and does all I want him to do to it and he Installs the rotating assembly, then I drop him off my heads and cam from Lloyd what's next? What should I buy next? Like after the builder builds it I'm taking it to my mechanic who is going to install it, my mechanic isn't pulling the old motor until the new one shows up simply because he does t want my car holding up one of his bays. What parts are transferable from my stock motor to this one? Can I have a list of parts in the order I should order then? Like the throttle body I am looking for already (I missed the as&m on here😔 I know I need 42lb injectors but I have no idea where to start or what brand. A list would really be awesome and kinda put everything in perspective!
Thanks again everyone!
well i dont want to have all this money wrapped up in parts and then have my self make newbie mistakes and then start all over! when i build my 69 ill take my time and do it my self and learn on that lol but for now im trying to get this baby done so i can atleast drive it to storage before the winter comes haha!
That having been said, the performance upgrades I'd have on my stroker (and I've have four strokers in my two Impalas and one Caprice):
1. 52mm Throttle Body
2. 1.6 ratio steel roller rockers....like Comp Ultra Pro-magnums
3. Long Tube headers w/hi-flo cats
4. High flow cold air intake
5. 30LB or 36LB fuel injectors
6. Properly sized head gaskets to bring 'quench' to .035"
7. PCM tune
BTW.....what Compression Ratio will your engine have?
KW
Hey thanks! Well as far as the compression ratio, I'm not exactly sure. I don't plan on on forced induction. Down the road I may spray it but not anytime soon. So what should it be I guess? And how do I go about making it a certain ratio?
