Lt1 coolant fill
Lt1 coolant fill
Hello everyone,
I am getting ready to start my new 383 Lt1. The radiator and block have zero antifreeze in them. I poured 2 and a 1/2 gallons of antifreeze in to my water pump which is connected up to the radiator and engine. I read filling from the pump itself will fill the block first. The only thing is that my radiator is now 3/4 filled. This makes me wonder if any antifreeze went into the block. I've read the coolant for an Lt1 motor is 15.3 quarts. I've put in approximately 10 quarts now. Any thoughts?
Thank you!
Thank you!
Hello everyone,
Thank you!
Thank you!
The following users liked this post:
Prince Antonerio (11-28-2021)
NewOrleansLT1 (12-04-2023)
Village Troll
Air pockets= hot spots, and it makes it more work for you to bleed after filling because those pockets of air may not surface for an extended period of time. It might take days before the system is completely bled.
What I've always done is opened both bleeder screws, start filling radiator until the t-stat bleeder starts bubbling coolant. Close that one and fill radiator until it's steady and about a 1/3 of the way down from the filler neck. Close bleeer screw on heater hose and start engine and monitor temp gauge and level via filler neck. I then watch the coolant return line from the heads that drains into the radiator (which is why I don't fill the radiator up completely). Once a steady stream starts coming out of it I fill the radiator the rest of the way and put cap on. I let the system build pressure and then check the t-stat bleeder. Usually the stream is steady and I close it back up and then open the bleeder screw on the heater hose to let the remaining air out of the system.
Because that is not the way you do it (even stated by GM procedure). Most of the air is purged during filling. I rarely have to do any bleeding after that. You trap air in the system if you don't bleed when filling.
