Help!!!!! 96 bird misfire!!!!!!
Ok so my buddy has a 96 firebird with the lt1 it has a bad misfire I assume it's causing the major loss in power it has new plugs and wires and also just had a shop change the distributor cap and rotor also recently done was head gaskets, o2 sensors, cold air kit, and a 58mm throttle body any help would be great thanks guys.
That's MISTER MODERATOR
Welcome to LS1tech!
Let's stick you into the LT1 section, they'll get you fixed up quick.
https://ls1tech.com/forums/generatio...g-threads.html
Also you don't need to put "HELP!!!!!!!!!!!!" in the title of the thread, its really annoying seeing that. It's not like people are going to see that and say "Geez he needs help bad I'm going to get right over there!" HELP does not work the same way online as it does in person....
I chased a misfire on my Caprice for over a year and changed plugs, wires, opti, ignition module, coil, etc. Basically everything that could have caused a misfire. Well I found out one of the new wires I put on was arcing(same place as the old wire) as I routed it in a stupid way. Doulbe check there is no arcing at night. (Way easier to see at night) How many miles? Has the original opti been changed? I would guess a crap aftermerket unit was put on if it has over 100k and that could be causing your problems. Also were the plugs gapped properly? Sometimes finding a misfire is like looking for a specific needle in a needle stack... usually its not that hard though.
