Strong Fuel Odor / Smell - Possible causes?
Hey guys, I have a 95 Z28 that even when its not running, just has a raw fuel smell to it. I've changed the gas cap twice, and checked the lines and connections for any leaks. Can't find any. I haven't replaced the fuel neck and hoses yet, but that's the next thing up...
So I'm wondering, what's the life of the charcoal canister / fuel tank ventilation system on our cars?
Anyone else have this problem?
This car has 150k on the body, but I just dropped a new motor in it, A/C blows ice cold, and basically this is the last thing I'd like to fix on the car.
Video for attention. LOL.
Thanks in advance!
Thanks in advance!
How bout the actual canister? Or do those never really go out?
I'm actually replacing my valve tonight, got it from the auto parts store. I've tried taking the canister out 2 times before but I always get worried I'm going to break the plastic harness holding it in place. Tonight I'm just gonna go for it. I've heard of the charcoal in the canisters breaking apart and the little fragments get stuck in the lines. Not sure if new canisters can be purchased, haven't researched that one.
Just replaced everything in my EVAP system due to codes. All parts are still available. Mine had venting issues so I pulled everything apart and there were chunks of charcoal everywhere. Unfortunately, while the codes are gone, I still have a strong fuel smell. I suspect the rubber lines probably have cracks causing the smell. I would replace those lines as well as I will be doing so to mine very soon.
I would think the rubber lines wouldn't be too hard to replace while doing the valve and canister.
You might want to look into the fuel neck possibly having some cracks in it, since I have replaced a few over the years. If any part of the neck has a rubber hose (which most of them do) they get brittle and cracked.
Thanks man, glad to hear parts are still available.
I had a problem with mine where I suddenly started smelling exhaust while I was driving, specifically at idle. It was realllllyyyyy bad inside the car. Turns out I had broken bolts on my (stock) manifolds, and there was a gap where it was pulling away from the head. Your issue could be something different, but it's worth looking into.
