what do you think about this cam
Old 01-28-2016, 05:23 PM
Filthy McNasty's Avatar
Default what do you think about this cam
Hi guys new to the site just wondering what do you guys think about this Howards custom grind Cam 560/560 lift 227/233 duration @ .050 l/c 112 with 1.5 roller rocker in a sbc 396 lt1 with ported and polished heads with lt4 intake. Car will be a weekend warrior.Some track time
Old 01-28-2016, 06:32 PM
wht97ws6ta's Avatar
Howards has some nice lobes. I think its a bit small for a 396 though. Whats the compression ratio. What trans and gear are you running?
Old 01-28-2016, 08:20 PM
the compression ratio is 9:0.1 for boost, either supercharged or turbo not sure yet.And the rear gears not sure of that either just yet. Thats why I'm on the site because I know some of you guys have been there done that and know what works and what doesnt
Old 01-28-2016, 08:57 PM
Catmaigne's Avatar
That cam is alright but more suited to a NA app.
You want overlap to be from -5 to +5. Negative overlap is better for turbos and positive for blowers. The cam you posted has 6 degrees.
Overlap = (Intake duration @.05 + Exhaust duration @.05)/2 - (LSA * 2)
The blower will want a fairly large duration split (8+) favoring the exhaust (eg mine is 226/239). Turbo will want a relatively small duration split or even none at all.
Old 01-28-2016, 09:08 PM
ok thanks ; wish I would have asked someone before I bought the cam.
Old 01-28-2016, 09:23 PM
how about if I put some juice to it like a 150 shot is this cam good for that
Old 01-28-2016, 09:28 PM
Catmaigne's Avatar
It would be fine for nitrous although it is kinda small for a 396.
A cam isn't that expensive in the grand scheme of things. I would be boosting it with 9:1 (assuming you have a forged piston and the right ring gaps).
Old 01-28-2016, 09:31 PM
ok so what should the compression ratio be for boost?
Old 01-28-2016, 09:35 PM
Catmaigne's Avatar
Most guys do 9-9.5:1
Old 01-28-2016, 10:00 PM
KW Baraka's Avatar
Originally Posted by Filthy McNasty
......lt1 with ported and polished heads with lt4 intake.......
Mmmmmm............I hope that's LT4 heads to go with that LT4 intake.
NOTE: LT4 intake with LT1 heads (among other things) IS NOT an upgrade!
Also.....if you stay NA with 9.0:1 CR.....not optimal; you'll leave a lot on the table. But that CR is very good for boost.
You can sell the current cam.....and get one with the same lobes but with a 115* LSA (4* advance). That would give you a cam with a 0* overlap .
Or....just use your current cam anyway. Not an optimal cam but still usable and will save you a few bucks.
KW
Old 01-28-2016, 10:14 PM
thanks for the replies guys.the need for speed is really expensive especially when making mistakes
Old 01-29-2016, 11:18 AM
HellTeeOne's Avatar
Cam isn't optimized for boost but it'd make a decent stick in a NA 350/355 with good heads.
What's the lift on a 1.6 rocker?
For a street-oriented boosted build with 9-9.5 SCR a favorite is the "high lift" version of the XE224/236. It's very proven and makes lots of usable power in a blower application.
Old 01-29-2016, 11:21 PM
KW Baraka's Avatar
Originally Posted by HellTeeOne
.....What's the lift on a 1.6 rocker?......
To easy.
.560" lift with 1.5 rockers = .597" lift with 1.6 rockers.
KW
Old 02-01-2016, 06:02 PM
Default Cam
ok finally got the cam I had the duration wrong. its a 4/7 swap .560/.560 279/285 dur. 112 lc intake c/l 108 .000 running clearance
Old 02-01-2016, 10:03 PM
Catmaigne's Avatar
Is this an Erson grind?
I hope you don't plan on running it with the stock PCM with closed loop. One cylinder on each bank will be messed up and it will screw with the fueling. The only way to do it correctly is to go 24x.
Old 02-02-2016, 12:09 AM
warriorcustoms's Avatar
Since things seem Mismatched What size Rods You gonna run with that 396 LTx??? 5.85" I hope!!!
You may want to give out the Specs on Everything to get the Best Help!!! Did AI or LE port the stock heads or are they AFRs or Darts??? All that kinda stuff matters when picking the right cam!!! A flow sheet will help Ya get the lift right... Do they flow best at .550 , .650 or .750 isnt a place to really Guess... Soo far the parts Your listing are best for a 355 Carbed or 24X conversion LTx!!! The Guys on here Will try to keep You from makin Expensive OH ***** if Youd Just Ask 1st!!! The Only Stupid Question is the 1 You Dont Ask!!!
Old 02-02-2016, 03:37 PM
KW Baraka's Avatar
......279/285 dur.......
Seat to Seat duration?
What duration at .050" Lift?
KW
Old 02-02-2016, 04:31 PM
hrcslam's Avatar
He could swap the injector plugs for 4 and 7. And the spark plug wires.
Old 02-02-2016, 05:39 PM
Old 02-02-2016, 05:46 PM
Thanks guys 6 inch I beam rods.And a guys named Tommy Gonzalez out in Pa. ported and polished my lt1 heads.I asked the guys about him here in New Jersey at Cartek and they said he 's really good at porting and polishing heads.The Cam was recommended to me from A guy named Scott at Howards cams.
Quick Reply: what do you think about this cam
