New Dyno Run after Cam and Rockers
Numbers are a little low considering the mods done in my honest opinion. But again, it is a mustang dyno. It is around a 40whp improvement over the last run. (No cam or rockers) I don't have the sheet right now, printer was out of ink, but ill show you a comparison soon. Ended up being around 317whp. Car and motor only have 53k miles
I will come back and embed the videos once I get access to a computer.
Ty McBride
Team Leader/Owner
McBride Motorsports
https://goo.gl/photos/W1tNEnFns5JukUFk9
Ty McBride
Team Leader/Owner
McBride Motorsports
is that from bone stock or with just boltons, if so thats not bad considering we would see a 35-50 horse gain with cam and rockers, of course depending on what cam, also, Im not saying they dont know how to tune LT's but a lot of shops tune like if its an LS in the timing and A/F tables..
Ty McBride
Team Leader/Owner
McBride Motorsports
Anyone else have input or experience on why the numbers might be low. I'm suspecting the Mustang Dyno as other people have mentioned also. Maybe it needs calibrated, maybe something was set up wrong. I do know that the heads are my main choking point.
Ty McBride
Team Leader/Owner
McBride Motorsports
Ty McBride
Team Leader/Owner
McBride Motorsports
What cam do you have?
the #'s are low compared to similar builds....but as you note, and others, Mustang dynos are known to read low. Was the data SAE?
your AF shows good. You could pull a few plugs to read them. Nice & tan is how they should look which would indicate a good tune. Dark would indicate rich condition so "something" would need to be looked into if that is the case (tune, leaking exhaust manifold)
I would go hit the 1/4 mi and do some runs. If you are hell bent on getting another "dyno" opinion, find a shop with a dynojet dyno
CC503 with 1.6RR
Timing I am not sure, I had no way to log the run at this time. I checked my A/F on my wideband during my last run at towards the top at at 5800RPM it was around 13:3-5 range. I really wish I had logged the run. But everything kind of turned out to be a last minute run.
A4 or M6?
M6 4th gear pull
My older cuz has a 96 Trans Am M6 WS6 with full exhaust, 1.6rr, custom Comp cam 220/230 112lsa, and a tune. The car has 100,000 miles and put down 355rwhp, 363rwtq on 19" rims C6 rims..
That's right around what I was expecting number wise for the HP
Village Troll
That's about right on par for a stock OBDII LT1. Right around that HP at 300'ish rwtq. My SS dyoned 278/310. A gaggle of other LT1 files I saw on that dyno where pretty much the same.
