car shake
Old 03-26-2006, 11:16 AM
djkyle25's Avatar
Default car shake
ok guys, maybe im just being picky b/c i used to have an acura and when it finally got up to 100-120 it drove as smooth as at 20mph, and i know its to be expected with a chevy to shake when u get over 90, but has ne one been able to do nething that doesnt cost that much that reduces/eliminates it?
Old 03-26-2006, 11:28 AM
Smokinlt1's Avatar
Alum driveshaft got rid of my vibs at that speed and above
Old 03-26-2006, 01:55 PM
djkyle25's Avatar
ooo how much does that cost and why does that change it???
Old 03-26-2006, 03:34 PM
omaha stylee's Avatar
^ because if the drive shaft is out of balance it vibrates
Old 03-26-2006, 04:58 PM
NOTAV6's Avatar
either that or you got something wrong mine will do 130-140 without any problems no shaking or rattles
Old 03-28-2006, 11:49 AM
curlyws6's Avatar
Check your tranny mount (if it's time for a new one, get the LS1 style factory mount). You will probably have to grab yourself an aluminum driveshaft (the driveshafts used around 1995 were out of bablance from the factory) to get rid of the "shakes".
Also, do not use the Energy Suspension tranny mount... they were out of tolerance, which threw driveline angles out of whack and causing BAD vibrations. I went with the 1LE driveshaft before discovering the ES problems. The car is smooth as glass now!
Old 03-28-2006, 11:51 AM
djkyle25's Avatar
how much is driveshaft aluminum
Old 03-28-2006, 11:53 AM
djkyle25's Avatar
how much do aluminum driveshafts run? and how much to intall them at a shop
Old 03-28-2006, 11:58 AM
curlyws6's Avatar
Check around with some of the vendors on the board (make sure you price around). I can't remember how much mine was, it's been a few years since I got it.
Quick Reply: car shake
