newbe ? about valve covers
i have a 93z28 with 1.7 rockers and need to change the valve covers have any of you used eather of these
http://www.jegs.com/images/photos/55550104.jpg
http://www.jegs.com/images/photos/778141131.jpg
if so which ones fit the best??? any help ???
thanks rick
thanks rick
Originally Posted by sdm1234
1.7 rockers? Is the rest of the motor stock? Have you notices any results in power?
haha oh man that's definitely not stock. i was just curious because i was thinking about future modifications.
I installed a set of the GM Performance roller rockers, and also wanted to use the ARP long studs and APR poly-lock nuts. They won't fit under the stock rocker covers, however.
So, I bought a set of the black crinkle covers mentioned above. Thought I could notch the right side to clear the alternator, but didn't measure carefully enough, and milled off a little too much along the top, and the notch is even with the #2 exhaust rocker. The "aluminum stretching tool" won't work on this deal.
Anybody needing a brand new left side cover, bounce back to me, and maybe we can work out a deal.
