cam possibility
cam possibility
ok guys im down replacing stuff and thinkin bout doin cam while im there, my car right now is full bolt on, and i dont wanna do no major big cam, just a moderate/ light performance one??? which one and wut lift/and stuff like that would i wanna get, and wut all adjustments would i wanna make on my car
im thinkin a small/mild cam for like 100-200, im thinkin lt4 hot cam size since i have stock heads, O and I NEed to Know if i put a hotcam in/ or one of similar size would i need to change nething else(and i mean NEED to) like, springs, lifters etc.
and does ne one know ne other cams that are similar size (218/228) as lt4 hot cam that are cheaper?? ne one have experience in the crane or summit cams???
ok well i jsut went ahead and bought the cam/lifter/ timing set package frmo comp cams, it is a hydraulic flat tappet type cam, i hope that is right, and the part number is CCA-SK12-238-2 at summitracing.com please feedback if that is the right one
Yea i agree with 96caprice. I would suggest the CC305 or the LT4 hot cam kit, the kit would be cheaper cause it comes with everything. You dont wanna throw a cam in with stock springs, rods.etc. I put a cam similar to the size of a CC306 on stock internals in my 91 TA (TPI) and i ran good for about a week and it pulled the rocker arm studs out of the head. I could have got away with it if they were screw in studs like the vette heads, but i had to learn that the hard way
for the hotcam or really any cam at that you need to replace your springs, lifters, rockers (1.6RRs if you can afford it) and all the necessary hardware.
To add a HOT cam ("or really any cam at that", you do NOT need to change:
Lifters - that's old school advice for flat tappet cams
Rockers - the HOT cam can be run with stock rockers, or 1.5 rollers. It's best with 1.6, but it doesn't NEED them.
Springs - the HOT cam doesn't even need a spring change if you stick with 1.5 rockers. It needs it with a 1.6.
Jim
