What Spring for cam with over .600 lift???
Old 05-25-2006, 12:14 PM
NotACop97Z's Avatar
Default What Spring for cam with over .600 lift???
I have a cam that will put me just over .600 lift for my ported and polished TFS LT1 heads and 1.6 rockers. I think it is about .628 but I dont have the card. What springs should I get or should I go back to the 1.5 rockers?
Thanks in advance
Pete
*Edit*
My Cam Specs
236/244 .585/544 @112 1.5
.624/.580 1.6
I already have the 1.6 pro mag roller rockers on a 7/16" stud
Old 05-25-2006, 03:28 PM
NotACop97Z's Avatar
No one has a big on an lt1???
Old 05-25-2006, 04:04 PM
lt197formula's Avatar
Sorry man I personally dont know a spring that would handle that lift call one of our sponsers and talk to them would be my suggestion.
Old 05-25-2006, 04:11 PM
blkchevyz's Avatar
i'm not going to be help with springs, but make sure you check your piston to valve clearence.
Old 05-25-2006, 04:14 PM
blkchevyz's Avatar
131-221426-16 Manley Performance Valve Springs, LS1/LT1/LT4/L98, 1.290 diameter, Double spring w/o damper, max lift .650"
did a quick search and found those on thunderracings site.
not sure if they will work on a hydrolic roller
Old 05-25-2006, 04:18 PM
NotACop97Z's Avatar
I may have to buy 1.5 RR on the intake side anyone wanna buy 8 pro mag roller rockers?
Old 05-25-2006, 04:29 PM
dhdenney's Avatar
Plenty of springs for that cam. My springs are Cranes that came with the Gold Race rockers. I don't have a PN handy though. Crane told me that they were good to .700. I would call Comp and ask about their beehive springs.
http://www.compcams.com/technical/Ca...07/288-290.pdf
Old 05-25-2006, 04:37 PM
NotACop97Z's Avatar
Wow thats alot of reading. I guess my head Machinest and I have alot or talking to do
Old 05-25-2006, 06:13 PM
96blkform's Avatar
I am running comp cams 977 springs with titanium retainers on my setup. They handle a pretty decent amount of lift I was told.
http://store.summitracing.com/partde...5&autoview=sku
Old 05-25-2006, 07:02 PM
NotACop97Z's Avatar
He told me I might need al longer intake valve... hell let me know when he takes my heads apart
Old 05-25-2006, 07:54 PM
95_Firehawk_Dude's Avatar
Not a solid roller is it? I think the duel springs are only good for .600" but I could be wrong. I was told to do beehive if you do a high lift cam on a Hydr. roller
Old 05-25-2006, 08:06 PM
NotACop97Z's Avatar
The cam is a Hyd Roller, and the trick flows are only good to .600, So ill def need new springs. Hopefully I dont need a longer Valve but ill see later... Does anyone with TFS heads know this already, or should I call TFS tomorrow???
Old 05-25-2006, 08:55 PM
Old SStroker's Avatar
Who spec'ed the cam? He should suggest the correct spring, installed height, retainers, pushrods, etc. for the rpm range you plan to run. Call him.
Old 05-26-2006, 12:53 PM
NotACop97Z's Avatar
After talking to everyone (Comp Cams, Machinest Trick flow)I am just gonna go with a 1.5 rocker, the cost of 8 pro mag 1.5 rockers plus what I can sell my 1.6's is less then new springs and the Machine work. Thanks to everyone that helped out!!!
Pete
Quick Reply: What Spring for cam with over .600 lift???
