Moroso CAI install HELP ME!
Old 05-25-2006, 11:12 PM
Kanes2413's Avatar
Default Moroso CAI install HELP ME!
I have a 93 lt1 t/a and im having a hell of a time trying to install this i took the fender defleter thing from under off but the plate is seemingly too hard to get onto the frame and how do i get the filter on?? any help would be great especially some pictures since i dont have a clue
Old 05-26-2006, 01:02 AM
Flores96TA's Avatar
what??????? You cant put a damn cold air intake on your car??Dude
1.Take all of your old **** off(intake tube after your maf but if 93 ????????check the search)
2.Then get the manual if it came with one.
3.No manual who cares just use some common sense the intake tube and filter need to face down.
4.Get a Flat headed screwdriver cuz you need to put the filter on before you install the kit.
5.come from the bottom of your drivers side of the car and take out the square shape of screws that are holding some of the that plastic crap in the way of your filter( keep all that stuff you might need to put in back.
6. Install tube and filter if it doesnt go take the filter off and install from bottom.
7. connect the tube to maf and tighten the screws and then go smoke some tires.
In questions ask or just use the search button or use the internet there is all kinds of **** out there . Peace
Old 05-26-2006, 03:36 AM
infinitebird's Avatar
just sell your car and buy a honda
Old 05-26-2006, 08:56 AM
Kanes2413's Avatar
It says specifically for my 93 so it does work and alot of people have the same kind i was looking for some quick help instead of searching around i know it goes on i just cant seem to fit it in the right now
Old 05-26-2006, 08:57 AM
Kanes2413's Avatar
btw it has a manual and shows everything i just cant fit it
Old 05-26-2006, 10:37 AM
NotACop97Z's Avatar
My K&N FIPKA was a PITA. Just take as much off the bottom as you can and dont overtighten the filter, the housing will warp. if your short like me you might need someone up top pushing on the housing while you push up on the filter.
Old 05-27-2006, 02:23 AM
4ced's Avatar
i dont understand why you cant fit it, its supposed to be a simple process... is there something in the way? heres an idea, get some photos of it while youre trying to fit it maybe we can be of more help
Old 05-27-2006, 10:42 AM
Kanes2413's Avatar
Well after some suggestions and help i finally got it in but by no means was it easy it was pretty hard to get everything fitted in there took awhile
Old 05-27-2006, 11:08 AM
blind527's Avatar
Come on guys.......Everyone needs to learn somehow...
Old 05-27-2006, 12:46 PM
96z28camaro's Avatar
Hey i just got a used moroso cai from a guy here on the forums and it fit fine but it was still a bit** to get in and i had to put the filter in from the bottom side after dropping the bottom plastic piece off so i could put the filter on the bottom side finally. I mean i guess if you do a few of these you get the hang of it and it isnt too bad but if you have never done it before stuff doesn't always go together easy the first time you attempt things.
Quick Reply: Moroso CAI install HELP ME!
