MSD cap and rotor kit..DEAD!
Old 05-31-2006, 01:25 AM
TwoFast4Lv's Avatar
Default MSD cap and rotor kit..DEAD!
Yes after 1,200 miles DEAD! Confirmed kill in pic below. same exact Ignition that kills Stock caps in 12-14k miles killed the MSD in 1,200
Current settings
MSD Cap and Rotor DOA
MSD Coil
16 year old(I kidd you not) MSD 6T with soft touch
NGK TR6 gapped to .040
EDIT
TO clear up what you are looking at. the black mark on the rotor is NOT supposed to be there. it is a carbon burn clean through the rotor. as dead short to ground when the ignition is trying to fire. The OPTI it self is fine and working great. LOTS of Spark going into the cap but not a damn thing coming out
Old 05-31-2006, 02:09 AM
Steve40th's Avatar
Is it that little burn mark at the base? That is what caused the engine to stop?
Before I ever blame the Opti , I disconnect the MSD 6 and plug the factory stuff back in, and sometimes you find something else.
Was there carbon tracks inside the cap? Cracks?
Old 05-31-2006, 02:12 AM
TwoFast4Lv's Avatar
LOL yes that black mark is a Carbon burn clean through the rotor. and about 10 seconds after the hood came up I unplugged the MSD and it was still dead.
Lots of spark going in not a damn thing coming out.
To be CLEAR the opti it self is fine
Old 05-31-2006, 02:14 AM
daniel6718's Avatar
wtf...it was arcing out of the rotor already? man i got a brand new gm opti its been my savier i went throught 9 o really optis...kept braking the little tabs on the rotoe and they would break up at 6k plus
no problems anymore pulling it to 7k a few times
Old 05-31-2006, 02:17 AM
NotACop97Z's Avatar
Sorry to hear about your loss man!!
Old 05-31-2006, 02:23 AM
Steve40th's Avatar
Okay. These Opti designs are a nightmare, and I think the extra HP of that MSD box doesnt help trying to overcome the design of the opti haveing to get spark clear across the rotor.
I am so glad I finally, after 5 or 6 Optis, went to a DELTEQ.
TwoFast4Lv's Avatar
I feel so special I paid extra for this stuff...so I could be dead on the road and pushed off by the guy from the FORD dealer I was near!
"wanna buy a new Cobra?"
"This will blow a Cobra away!"
"before or after we get done pushing it?"
THANKS MSD!
Old 05-31-2006, 02:25 AM
TwoFast4Lv's Avatar
Originally Posted by Steve40th
Okay. These Opti designs are a nightmare, and I think the extra HP of that MSD box doesnt help trying to overcome the design of the opti haveing to get spark ckear across the rotor.
No they are barely good enough for stock...but I do not changing plug on a regular basis so I have to use a MSD to keep them clean
Old 05-31-2006, 02:27 AM
Steve40th's Avatar
ANother thing to, when Dynaspark puts there Opti out, there instructions give allot of detail in fitment of the Opti. WHen we build our engines, our gaskets/sealants, maching, cams etc etc all change the fitment of the Opti on the Engine. I think that is why some person can have there Opti go over 100k miles, on a stock engine, but modified ones chew them up (of course rpms over 6300 werent meant for stock Optis, as that was the LT4's limit)
The Opti design is flawed and we are paying for it.
Old 05-31-2006, 02:29 AM
TwoFast4Lv's Avatar
Yes we are very careful here to install them correctly and make sure things are lined up properly All to many times you see some one slapp it on and break it real quick
all the ones I have killed have been from carbon tracking the cap till now
Old 05-31-2006, 02:32 AM
Steve40th's Avatar
I was speaking in general terms for the public. I have installed 2 Dynasparks and after they broke, and I blamed Dynaspark, I found out it was my engine build. The Reluctor ring on my 96 LT1engine had a foreign material in between the ring/crank gear so the thing vibrated the crap out of the Dynaspark, and now with the DELTEQ all is good, because I had to tear it down and already had the DELTEQ in waiting. But nevertheless, **** happens.
Old 05-31-2006, 05:34 AM
Honda Hunter's Avatar
Is it even worth having the MSD 6AL? I'm starting to hear way more bad than good about having it. Now that I think about it Ive never heard anything good like gains etc. At what point is one needed? I dont want to lose my Dynaspark because of this pos.
Old 05-31-2006, 06:35 AM
Heatmaker's Avatar
the msd is an engine life saver. The soft touch rev limiter is a good safety net for people that race around thier red line.
Old 05-31-2006, 09:20 AM
TwoFast4Lv's Avatar
What Heatmaker said. My car will foul plugs with out it and the Soft touch rev limiter has been a Life saver over the years
Old 05-31-2006, 09:34 AM
what pill do you have in it?
Old 05-31-2006, 09:37 AM
TwoFast4Lv's Avatar
I have a 7,200rpm pill in it.
I just got off the Phone with MSD and they are being very helpfull as I expected.
Old 06-01-2006, 06:03 AM
scoob8000's Avatar
Got any pics of the inside of the cap?
I know the spark is going to follow the least resistive path, but why that was down the side of the rotor is beyond me.
Almost looks like the spark jumped from the tip of the rotor to the side of the rotor and traveled down to the optical pickup disc.
Any tracking to a specific cylinder on the cap? Just for s**** and giggles I would read the resistance of the plug wires, maybe one is a higher resistance and the spark occasionaly found another way to ground.
Concerned because I just put this cap on my car, and have been preaching about how good the rotor design is compared to stock.
[EDIT]
Just thought of something else. Since the MSD 6 is a capacitive discharge, I'm wondering if the spark duration is too long for the opti? Fires one cylinder, and still has some spark in it as the rotor is between two cylinders. You would still think the spark would jump to the nearest brass post though. <scratches head>
Old 06-01-2006, 09:41 AM
TwoFast4Lv's Avatar
Just got off the Phone with MSD. I will be sending it back so they can cut it apart. The burn mark starts at the screw that holds the rotor together. We will know more when they get done.
I know how you feel BTW I have put a few of these on customer cars after telling them how great they are.
My Delteq should get here today. I just need to get the other MSD parts coming!
Old 06-01-2006, 02:34 PM
scoob8000's Avatar
Awesome, definatly let us know what MSD comes up with. Hopefully just a freak issue.
Old 06-01-2006, 02:39 PM
streetwarrior96's Avatar
Man my orgional opti lasted 80,000 miles 96-05 9 years of use
Quick Reply: MSD cap and rotor kit..DEAD!
