throttle response
Old 06-20-2006, 06:26 PM
subhumanzz's Avatar
Question throttle response
94 z28. whenever im at a stop if i smash the pedal it bogs bad and then launches what could cause this? i have a new opti i thought that would help and it did a lil bit but not as much as i though it should.think maybe its my throttle postition sensor??? i'm stumped help if ya can.
Old 06-20-2006, 07:28 PM
contraststriker's Avatar
yes definitely sounds like it could be your TPS, and if it isn't that your timing is being retarded by some rogue noises.
Old 06-20-2006, 08:22 PM
subhumanzz's Avatar
knock sensor???
Old 06-21-2006, 04:45 AM
Originally Posted by subhumanzz
knock sensor???
Yes, I suppose your knock sensor could be bad, or even your knock module though I rarely hear of those crapping out.
Old 06-21-2006, 04:59 PM
road_rage187's Avatar
mine does the same thing it bogs really bad, and wants to die
Old 06-21-2006, 05:12 PM
redhot lt-1's Avatar
had the same problem try your plugs and wire but don`t rule out your knock sensor i would try the lt-4 knock sensor
Old 06-21-2006, 05:21 PM
UA-Plumber's Avatar
Had the same problem on my S-10. It was the plug wires. 110,000 on them unknowingly. Were fine until I changed the head gasket and moved them around a lot. When I put them back on the truck spit and spuddered only on quick accellerations. Put new ones on and it drove fine. Just something to look into though.
Bryan
Old 06-21-2006, 06:01 PM
an LT4 knock "sensor" does not exist, only an LT4 knock module does. The sensor is located in the block, the module is in the PCM.
Quick Reply: throttle response
