4l60e or 700r4
Old 06-22-2006, 04:14 PM
slowmofo's Avatar
Default 4l60e or 700r4
Well just got the car back and the tranny is TOAST. Any kinda pedal over 1/4 and it shutters your teeth out of your head. I really don't want to go with a re-build on this again. I have a 700r4 and was wondering what you guys thought of having it completly built. I have a friend who is freinds with a very well know tranny builder here. He is gonna try and get me a deal. I know the internals are the same as the 4l60e - the electronics, but I really am having problems with the electronics and my stall. The 94 pcm is pissing me off. I know some of you guys have built 700's..worth it or rebuild the 4l60e? Take in mind I will still have to deal with the PCM if I go back with the 4l60e.
thanks for any input
Old 06-22-2006, 06:18 PM
96capricemgr's Avatar
The shift point and drivability tuning with the 4L60E makes it the right choice. You already understand the hardparts are interchangable so why swap backwards on the valvebody.
1.7s are no big deal for a properly tuned OBD1 pcm, there are guys going faster without issue, fix that problem and keep the electronic tranny.
Old 06-22-2006, 06:23 PM
hashtagBMW
Speed Density's Avatar
The only downside to the 700r is the shift points, they are much harder to change. But on the plus side they are a little stronger than the electric version.
Old 06-22-2006, 06:59 PM
slowmofo's Avatar
very true, the 1.73 was with the f-ed up tranny and the slipin like hell stall. + 90* weather. I might be able to squeeze a 1.70, 1.6X out of it.
The car is not going to be a daily driver anymore, A hyundai will take its place, its going to be a Weekend, bracket racing car.
I have been thinking this over the past few hours and I think your right, the 4l60 is the way to go. just gotta get it built right....and then figure out this shift problem...
Old 06-22-2006, 07:04 PM
Chopstix's Avatar
if it is going to be a track only..weekend street bruiser...forget both the 700 and the 4L60E and go with either a th350 or th400...both can be had for much less than a built 4L60
Old 06-22-2006, 07:07 PM
slowmofo's Avatar
True, I just don't have a way to tow it to the track (120miles round trip)
But that was another route I was seriously considering. TH350 with a nice stall.
Old 06-22-2006, 07:09 PM
streetwarrior96's Avatar
4L80E !!!!!!!
Old 06-22-2006, 08:00 PM
zlover129's Avatar
Originally Posted by streetwarrior96
4L80E !!!!!!!
beat me to it
Old 06-22-2006, 08:43 PM
Chopstix's Avatar
just get taller tires for the street...
28" tires w/3.73..
65 = 3000 rpm
75 = 3500 rpm
edited....#'s listed are with 28" tall tires
Old 06-22-2006, 08:47 PM
383LT1S10's Avatar
Hell yeah if it's going to be a playtoy bracket car a th350 all the way and like pointed out above it will still be drivable enough to take to the track and back.
Old 06-22-2006, 09:42 PM
We already agreed the hardparts are the same. Explain to me why you think the 700r version is stronger? The 4L60E gets an undue bad rap one because it was put behind stronger motors and subject to more abuse and also because there are more people who can build it wrong than right. I let a local shop with a good rep build it for me once, went bad in a little over a year. The second time I did it right and went with www.pro-built.net I have more time and miles on it with much more power already and the last pan drop was spotless no signs of giving up. The b-body weight is a lot of extra abuse too.
Old 06-22-2006, 09:49 PM
If you want serious abuse... (not to say the others can't take it) the TH400 has been a bad boy out of the factory. But I guess it comes down to who know their **** on building a tranny. I personally have never been a fan of the 700R4
Old 06-23-2006, 04:38 AM
slowmofo's Avatar
Well, I have some choices to mame, thanks guys....
Quick Reply: 4l60e or 700r4
