Getting ready for drag racing
I have an lt1 93 a4 camaro and I want to use it for drag race only. first I'm thinking about taking of weight. what are the stuff that I can take of my car? then i'll be looking for a real agressive heads and cam package
06-there is a ton of stuff you can take out if its just a drag car only. You can take out all the seats and console and put in a lightweight race seat, remove carpet noise deadner, all the a/c stuff under dash and a/c and smog equipment under hood.
That should get you started...you can save alot by replacing pars like lightweight fuel cell, fiberglass hood, replacing glass with lexan, etc. etc.
Good luck on your car.
Mike
Mike
Tons of stuff you can take out. Ny friends got his down to around 3000 lbs, and hasn't gotton real crazy like some, his has carpet but his dash is gone, he made a custom dash out a a sheet of abs plastic, cut it to fit. open the hood and you see the engine and not much more. Ill try and get some pics of it...
This ought to help you out:
https://ls1tech.com/forums/drag-racing-tech/17319-weight-reduction-list.html
I'd also get some skinnies on there to reduce the rotating mass which is more important than reducing weight by say putting a lighter weight hood on etc. And I'd highly consider getting a roll cage which will add weight but could possibly save your life and may be mandatory depending how fast you decide to make your car.
Originally Posted by 97blkz
What stealth said and posted the link. Easliy get the car into 2900-3000lb race weight. Big stall , big tire and big spray!
.....and dont forget the big rear end u have to replace the 7.5 10 bolt with.
