Banjo Bolt in the back of the heads. Help!
Old 07-08-2006, 06:53 PM
LS1 Eddie's Avatar
Default Banjo Bolt in the back of the heads. Help!
Okay I'm trying to get everything assembled outside the car while I can. I know for a fact there is a banjo bolt in the back of the heads that serves some kind of useful purpose. I was wondering if anyone knew what I was talking about? Anyone have a picture? Most importantly a part number? Could somebody help walk me through this so I could get this car back on the road.
Does Secondary AIR ring a bell?
Old 07-08-2006, 07:06 PM
Heatmaker's Avatar
It for the coolant tube I think the heads need to be installed first before you put the piece on.
Old 07-08-2006, 11:47 PM
LS1 Eddie's Avatar
That sounds on track. I'm wondering if I could pick it up at a parts department or even better have a part number for Dal and get it off him.
Old 07-09-2006, 12:41 AM
1991 RS/SS's Avatar
I dont know the part number off hand, but I picked the bolts up at a Chevy dealer. I had him bring up an exploded diagram of the engine and found the parts that way. You will also need the four rubber washers as well. One between the head and banjo and one between the banjo and the bolt head, on each side. Good luck.
Old 07-09-2006, 02:06 AM
whynot's Avatar
I bough a couple of barbed 90's with npt on the other end, ran a rubber line after that, the stock banjo bolts and I had a dissagreement, and I won. they were the biggest pita to remove and replace heads.
Old 07-09-2006, 03:33 AM
That's MISTER MODERATOR
Paul Bell's Avatar
LT1 steam pipe behind heads (93-94) (includes bolts, seals, hose to radiator) = 10108635
LT1 steam pipe behind heads (95-97) (includes bolts and seals) = 12556260
LT1 coolant steam pipe seals (93-97) = 10108689
LT1 coolant steam pipe bolts (93-97) = 12552974
Taken from the parts list section ( https://ls1tech.com/forums/general-maintenance-repairs/336981-lt1-lt4-ls1-ls6-f-body-part-numbers.html )
It's well worth buying a new set if the old is crappy, it's cheep and these pipes carry hot coolant directly from the heads into the radiator.
Old 07-09-2006, 06:01 AM
the_merv's Avatar
LS1Tech 10 Year
Did they break when you took them off or something... I have to remove my Heads soon to change a Head Gasket.
Old 07-09-2006, 06:57 AM
camar0corey's Avatar
Mine didn't break, I found reinstalling the tube with the heads off the engine was easier during reassembly. I just rigged it up with my intake to get the pipe right. It took maybe a extra minute to get the heads lined up, but with another person present I'd put the tube on before putting the heads back on the car.
I got the driver side one off somehow when removing, it sucks. It might not suck if you have the tool the manual was saying I should use, well I was tired of buying more tools, I now have twice as many tools as I used to own when I did my head gaskets.
Quick Reply: Banjo Bolt in the back of the heads. Help!
