A.I.R. system removal
Originally Posted by @nthony
so would doing the !AIR and having it tuned out make you not pass smog? yeh and i live in CA where they got you by the nuts with emissions.
You could just do a check first since you have a 94 all you have to do is unplug the AIR pump and make sure the fuse is good and you wont get any SES light. Just have it checked with the pump unpluged and see if it passes or not if so then your good to go if not just plug it back in.
well my co worker is a smog tech so i may do it one day at work when theres nothing to do.
Originally Posted by borninatransam
strangely enough neither one of my lt1s ever threw a code for the air pump. and i figured it would on the black car cause the connector got melted and pushed the pins together
is there something in the 95s that cause it to not throw a code? ive never heard of that.
