7000rpm
Old 08-26-2006, 11:50 AM
Ari G's Avatar
Default 7000rpm
Ok.here is the problem
I need to spin the motor to 7000rpm but canīt go higher tha 5000rpm them it pops and looses all power
New stuff:MSD Coil,Wires and Cap and Rotor kit,NGK tr55,255l Walbro and A tune from PCMforless
What could be causing this?
Old 08-26-2006, 11:56 AM
daniel6718's Avatar
opti......
Old 08-26-2006, 01:12 PM
streetwarrior96's Avatar
can that cam handle 7000 rpm????? whats the LSA on it? Your cam is almost like mine and I shift at 6500 rpm. But even then you should be getting more than 6000. What is rev limiter set at?
Old 08-26-2006, 01:24 PM
daniel6718's Avatar
heads help it pull to 7k i bet...
Old 08-26-2006, 02:01 PM
GTP PWR's Avatar
easy. the tune from PCM for less. I have the same problem and have scheduled a duno tune.
the tune is holding you back...............
Old 08-26-2006, 02:25 PM
daniel6718's Avatar
i think he already has a tune...
Old 08-26-2006, 06:02 PM
roughneck427's Avatar
Possibly running out of valvespring or springs were not set up correctly installed height
Old 08-26-2006, 07:17 PM
wrd1972's Avatar
Why do you NEED to rev to 7K on stock bottom end and those specs in your sig
Old 08-26-2006, 07:43 PM
Honda Hunter's Avatar
I'm willing to bet the farm there is no reason for him to spin to 7000 with that setup.
Old 08-26-2006, 07:49 PM
with that small of cam @ 7000 it is not gonna give you anymore power, you'll be lossing it especially if the LSA is 112 or higher. 7000 is pointless for that setup
Old 08-26-2006, 07:54 PM
Ari G's Avatar
112 LSA on 108 IC and the cambuilder told me 6-7k is peak power,but installed straight up
Opti is fine
Iīm thinking about the tune and fuel tables because it farts at 5000-5500rpm and looses power
Heads are ported to flow 270s at 0.525 lift so no problem,cr is about 12:1
The rev limiter is off
Old 08-26-2006, 07:57 PM
Opti is fine
It should be the tune, also he is giving you an operating range of 6-7, doenst mean it's gonna give you the 7. what Runners are yuor heads?
curlymojo's Avatar
Old 08-26-2006, 08:07 PM
Ari G's Avatar
allmost 7k,to about 6.5-6.8k
Stock heads ported my Fast Engeneering,
Old 08-26-2006, 10:12 PM
Ari G's Avatar
Talked to Alvin and he says that the motor canīt even come close to 7k???
Is anyone turning there motor between 6-7K in here?I know there are a few,donīt remember who?
GTP PWR and streetwarrior96 any commentīs?
Old 08-26-2006, 10:34 PM
Alvin's Avatar
Your setup looks like it shoudl be shifted at 6500-6700
If its a hard breakup at 5k you likely have a bad opti or other ignition issue. I may be able to see something in a datalog if you sent one to me.
A 93 car will not turn 7k or past that. The computer shuts the car down I know cause i've tried and even happen again on a solid roller 93 LT1 I did here locally about 2 weeks ago.
Old 08-26-2006, 10:43 PM
travie319's Avatar
I shift at 7000........no pops......!
check your tune......also what springs are you running?
5k is very low....to start popping! sounds like your opti.....
Old 08-27-2006, 09:25 AM
Ari G's Avatar
I have a fresh MSD Cap and Rotor and it stops pulling around 4k and pops at 5k and stops
967 springs Double
Old 08-27-2006, 09:34 AM
I'm going to go double or nothing your opti is to blame.
Old 08-27-2006, 09:49 AM
Ari G's Avatar
Well you loose I have a fresh unit and this starts way before 5500rpm where the stock unit is fine,4k and no power
Quick Reply: 7000rpm
