my383 setup, what do you think
What do you think of my 383 set up, here is a list of everything:
Eagle forged 383 Rotating assembly
ARP main studs
hooker longtubes
42 lb injectors
dyno tune
1.6 roller rockers
comp cams guideplates
Crane Chromoly pushrods
5/16 in. Diameter,7.178 in. Length,ball ends,Hardended, set of 16 comp. cams rocker arm studs
Rocker arm studs,7/16-20in. Thread, 1.75 in. Effective Stud Length, Kit
Patriot Dual valve springs
Spec stage 4 clutch
NGK-TR55 spark plugs
AC Delco Spark Plug Wires
stock ported heads that flow well
242/248 584/579@113' cam
The engine is going together in a week, so let me know if you think I should change anything, or if something doesnt seem right. I'm spending $10,000 on my engine including all parts, machine work,heads, and labor, so I want to make sure everything is perfect as it can be. what should my RWHP be.
what do you think of my cam, will i be impressed... thanks for any info.,its greatly appreciated Jay
ARP main studs
hooker longtubes
42 lb injectors
dyno tune
1.6 roller rockers
Spec stage 4 clutch
The comp guideplates do not fit well and pushrod length needs to be determined AFTER the motor is together. The cam is a sheeple cam nice and big to impress your friends but from the short specs I bet you could do A LOT better unless you are gooing for emmisions then maybe just scale it back to better.
BIG cams on a wide LSA are too allow folks to fuckup cam selection but still have it drive OK and they never know just how much power they are missing.
how much does a custom ground cam cost? and where can I get it done, I am located in Cleveland Ohio...My car is at GMR SPEED. how much more HP can I pick up with it
and yes my heads were flowed...I can post the numbers up later
and I am not going the emission route, I have no cats, no egr,etc. I just need a badass cam that makes some sick HP. Nothing too big, just enough to be a lilcrazy
the compression will be 11.5 : 1
and its a M6
and its a M6
Setup sounds good, but on a 383 if you are looking for max effort ported aftermarket heads would be the way to go IMO. And a cam on a norrower LSA will make more power. If these guys think your cam is huge, they would flip at mine lol, and I drive it on the street.
Just for reference my setup is:
forged eagle 383 assembly (internal balance)
srp -5cc pistons
TFS heads ported by Lloyd elliot (2.08/1.625 valves, right at 300cfm intake)
Intake manifold ported by Lloyd elliot
1.6 Pro Mags, Morel Lifters, Hooker LT's, Elec cutouts, CSR electric WP, holley 58mm TB, Canton pan, splayed 4 bolt main, McLeod Street Twin clutch, !AIR !EGR, other stuff...
approx 11.5:1 compression
Cam is pretty large for hydraulic roller over .600 lift intake and exhaust, high 240s duration on a narrow (less than 110) LSA.
srp -5cc pistons
indeed. and it pulls like F'ing crazy right up to 7K, idle's OK (with a pretty strong lope), and I wouldn't change it for anything. hell I paid someone almost $400 to "acquire" me an emmisions pass ceertificate just so I could run this cam.
I am on the other end of the spectrum...my cam is a Joe Overton spec that is 22X/23X .568 on a 111 and it pulls like crazy, but I only have to rev it to 6300...Its got a nice choppy 900 rpm idle and should help me go around 120ish with my recent changes...I don't like BIG cams for the street and I've beaten plenty with wayyyy more cam than I have...just be careful, bigger isn't always better...(with cams) hahaha
--Alan
--Alan
will a custom ground cam help me at all? or should I stick with what I have
and why Chromemoly push rods???
WILL THE CAM I HAVE NOW BE A PAIN IN THE ***,WITH A REALLY BAD IDLE? like not streetable....
custom cam takes in all the aspecs and puts the valve timing wher it needs to be for best performance. I'm gonna say a custom cam will give you a broader power range with more HP, and likely not have to spin it quite as high.
--Alan
--Alan
For the guy that started the thread, a custom cam is definitely the way to go if you ask me, and bret and joe are about the two most reputable guys around.
