OBD-II to OBD-I
Guest
Posts: n/a
OBD-II to OBD-I
One of my buddies heard that by going from OBD-II to OBD-I you can get more power out of a tune because there are more paramaters that you can change and as we know its easier to work on the car with less sensors.
Does anyone know if this is true or not? I still have OBD-II in my car with a mail tune.
Guest
Posts: n/a
Originally Posted by 96capricemgr
A few reputable tuners do say they can get more out of OBD1 but your ideas on why are flat out stupid. Sensors are what allow injection to work so very well not a hinderance to it.
Before you call someones ideas stupid read their post a few times and realize they are talking about two different things...... and avoid making yourself look like a complete idiot in the process....
So your saying every OBD-II sensor is needed and can't live without?
Wow, guess I better get Ion to reprogram my rear 02's back in... since those are sensors.... pretty sure there are a few others on a OBD-II car thats not on the 1 cars..... but those could be the only ones, I was just trying to figure out.... for 10hp its not worth me converting over...
I think the reason they go OBD I is becuase it is easier/cheaper to tune. and I know for a fact that the rear O2's are not what "caprice" was talking about. Did he make himself look dumb? nope... but you sure showed your own irnorance again. OBD II cars have a few more sensors, and features, and run ever so slightly different. like the way the Knock sensors work( I forget just how it's different) but I do know that the OBD I PCM needs a small mod.(to work with the differnt Knock sensor) you solder 2, 1 ohm resistors inline to 2 pins to correct the Knock sensors, then all you need is the OBD I program.
9-Second Club
You don't have to solder anything in. Just turn off DTC 43. The knock sensor will work normally. My car makes close to 20 more rwhp with an OBD1 PCM, but on many other cars I have been able to make the same power either way. Cheaper software and cable is the biggest advantage.
OBDI Is a lot easier to tune. All you need is a tune e-mailed to you and then you upload it with free software. OBDII you have to have something along the lines of LT1_Edit in order to upload it. I've actually never heard of a power difference between the two.
9-Second Club
Guest
Posts: n/a
Just some 19 year old punk!
uhhh huh....
And he mentioned sensors, none in particular.....
This forum is for people to ask questions... I am sure I could ask you a question that you would not know the answer to then I could start laughing at you... and from what Ed is saying who is a wll known tuner you are wrong in your soldering comment... OOPS! Please don't post unless you are very sure in your reply...
Yeah were is this free sofware....
Ed, I did not know you posted on here, when I get my car re-tuned do you think I should go 1 then?
9-Second Club
Originally Posted by JUICED96Z
uhhh huh....
Where does this free programming software come from?
The "free" OBD1 software is TunerPro, they have a donation option though which I would hope most choose to use.
OBD2 has a CPS and extra O2s as the big sensor differences the CPS makes missfires easier to trace and the extra O2s do not affect performance in any way so why would OBD1 be easier from a sensor standpoint????
I am running a OBD1 swap but as the intelligent folks here already covered that was for the cheaper tuning/logging it offered especially 4-5 years ago when I first began to play with it.
