Benefits of Internal Balancing
Old 12-31-2006, 06:29 PM
95FbFormula's Avatar
Default Benefits of Internal Balancing
I am in the planing stages of my 355 build. I know what pistons and rods i will be getting my question is what kind of gain or advantage would i get from also getting a new crank and having them all balanced instead of just buying the pistons and rods and using my stock crank. I wont be running any type of FI or spinning past 6700.
Old 12-31-2006, 06:47 PM
A-man930's Avatar
Interested as well... but can't you have the stock crank balanced?
Old 12-31-2006, 07:17 PM
kngkahious's Avatar
u can buy all of your parts or use some u already have if there good parts.take tham to a machine shop and have it balanced as a system.there is less stress on the parts and they work together as a system not aginst one another.most of the time if u r going to have a high reving engine it is a must so the parts dont come apart.and rattle loose.it will also reduce friction and ware on your parts.
Old 12-31-2006, 08:23 PM
gradez28's Avatar
whats the average cost for a balancing job?
Old 12-31-2006, 08:47 PM
Commando's Avatar
and excuse my question, what is balancing??
Old 12-31-2006, 09:10 PM
balancing is taking and adding wait to the rotating assembly so it works together and not against it self.
Old 12-31-2006, 09:32 PM
the_merv's Avatar
I got mine Balanced when I re-built mine. It cost me $400, and it's within grams..
What they did was take every piece of the Rotating Assembly(Crank, Rods, Pistons, Bearings) weigh them, then number them(#1, #3, etc) to where it is close. Then they put counter weights on the Crank simulating the Rods and Pistons, spin it, and in my case, added weight to the Crank. I used a factory 350 Crank.
It is recommended for high-revving Engine like mentioned before, and you can tell a difference when you drive a car that is balanced, and one that isn't. Throttle response is immediate, and the RPM's are smooth and quick. It doesn't stay in gear long, goes right through them. I have it tuned to shift at 6100RPM, Limiter is at 6500RPM, and when you get into it, it goes. I have decent tires on it too, and it will spin them no problems..
If you got the chance to do it, get it done. The car is so much better.
Old 01-01-2007, 02:01 AM
Gun5's Avatar
ya i was gonna have mine done but i woulda had to wait like 1-2 more months to have it balanced.. my car wraps quick as **** i put my foot down and its up there i needa get a bigger TB =/
Old 01-01-2007, 11:13 AM
engineermike's Avatar
Whether or not you get a new crank doesn't have anything to do with the need for balancing. If you change the pistons or rods, then the stock balance job is no longer valid. You can have it balanced with the stock or aftermarket crank.
Balancing an engine will not make more power or give it more response. Balancing is mainly a reliability step that will make bearings and the crank last longer. The higher you rev the engine, the more critical the balance is.
Many shops will balance to under 20 grams and call it good. I got mine down to less than .2 grams, which is way overkill for my engine, especially since I don't rev mine past 6500 rpm.
Mike
Old 01-01-2007, 02:24 PM
Commando's Avatar
aha, awesome info. thanks
Old 01-01-2007, 05:35 PM
Internet Mechanic
BlackScreaminMachine's Avatar
A big benefit is that it puts alot less stress on the end bearing and its distributed evenly.
Old 01-02-2007, 12:15 PM
A-man930's Avatar
Awesome info guys, thanks!
Quick Reply: Benefits of Internal Balancing
