Comp cams 292XFI
anyone runing the Comp cams 292XFI
I just got my cam,I would like to know if anyone is running this cam,the gross liftis in.584,ex.574. the duration @.050 is in242, ex248 on a 113.0 lobe separation. the car is not a street car.
Haha thats funny i just pulled my motor and did a cam/intake swap for that same cam.. God i hope our cam works good and mine is a street car. You cant really find anything on them cause they just came out.
I'm going to be using one that's one half step down from that one. I hope it runs well. I didn't think my heads would flow enough for that one. Let us know, though. What do your heads flow and where did you get them done?
I bought the trick Flow heads at the same time I got the cam, the heads have not come in yet.My boddy at bottlefed racing is geting more work done to them when I get them. I hope they flow some good #'s.When they are done I will let you know the #'s. GOOD LUCK ON YOURS
Never heard of a motor not liking an LSA. The difference between the 113 LSA and 112 or 114 that most everyone else runs with shelf cams is minimal. I think they just went to 113 instead of a 112 to make it slightly more "streetable" with those agressive lobes. I got mine on a 111.
Originally Posted by Armyman2445
Ive got the 280 XFI in mine. Only problem your gonna have is an LT1 doesnt like a 113 lob seperation. It will take a good tuner a few attempts to get it dialed in.
(I would not try running my car with this cam with the stock 323 gears and a stock stall, the car would be a pig)
Originally Posted by SStrokerAce
onephatZ28..... don't put that cam in a stock bottom end, it will be a pig. A stroker, it would be decent but not in a 350-355.
Bret
Bret
I am wondering why you think it would be a pig? I guess I should have included more info about my car.
It has 4.10 gears with a 3500 stall. I will be running a 175 nitrous on it. I am also going to run the 1-7/8ths long tube headers. Do you still think it will be a pig?
I also plan on building stroker engine and use the same cam with it.
Bret
Because I do cams for these motors everyday and I know what works and what doesn't. That's just way too much duration for a LT1 350 Bret
My spin on this subject is...Duration is like spice, too much can spoil the stew.
What do you guys feel about that cam for my setup? I have a stage 2 equivilent heads 383 stroker forged everything that cam with matching valvetrain stuff 4500 stall th-400 9" ford?
I'm not a cam guy but I can give you IMO.
The 4500 stall sounds good but the 11 to 1 CR might be on the low side for that much duration and overlap.
I would be curious as to how the superam intake liked that much cam.
