Ah F*** - RANT Time
Ah F*** - RANT Time
Well I went out to the shop with my mechanic today and we got my car inside he put some bolts in my crank hub so I could turn it manually because he was gonna set the posi locks..
so dumbass me screwed the 3 bolts in alittle more because they where wobbling around and I didnt know there was a clearance issue with the MSD probillet opti so now the case (corner of it the botton round part) is all smashed the **** up i know its pretty thick plastic.... but it should be fine right?? as far as sealing or should I throw some silicone on it just to be safe?? I didnt crack it thank god
here's where it crushed the plastic (bright red at bottom)
on a side note I we got all my posi locks adjusted except around 5-6 of them because the lifters are bad **** intake has to come off again those damn springs killed my lifters, studs and everything
ya my dumbass fault and I dont have money to begin with.. it didnt crack it like i said just crushed the plastic u know like when u rub up against it.. if it runs good im sure just leave it ill do a better inspection when its on the lift
im just worried about it not sealing good what else could it **** up ignition wise?
Originally Posted by fergymoto
Depending on just how smashed the cap is, I suppose the rotor could tag it. It would have to be pretty bad though.
oh its just the cpa thats dmged i know i could get away with just a cap definitlybut i dont want to replace anything its only a few mm worth of crush how do i tell if anythings rubbing?? it didnt really push it like bend or warp it just crushed it u know
its only pushed in this much
between those bars its feelable and seeable but not that much and its just on the edge
Take it off and take it appart. If you are lucky it will just have to replace the cap.
Why didn't you just use the starter to crank the engine over?
I would assume you had sping binding problems?
so we where just doing it by hand and dumbass me ofcourse.. i dont see how it could be MORE then the cap the cap isnt pressed against anything its just like i put a dremel to it and took some plastic off.. .. but its not open its still sealed ill take my chances and try it ill try and get some pics to
I just thought that if you had to take the intake off and where doing work any way it would not be a bad idea (if it where cracked). If the cover its self is not cracked or the seal compromised, then you probably didn't hurt it.
It's better to kill a $150 starter (LT4 mini) than a $500 distributor.
It sucks that you are having such a rough go round with it. Did you figure out why the valve train is shot?
but we are gonna replace the lifters this week both sides.. set everything.. im gonna inspect the Pro Billet maybe snap a pic or something im praying to god its alright i really have no money
I did that too, I screwed in the bolts all the way and smashed my opti, but it was bad anyway, took a dexcool shower thanks to a bad waterpump.
I was reading and I was like WTH are posi locks, then I read that you had bad lifters so I was OH. Well its poly locks. Anyways. Good luck, hopefully it only gets better and not worse
well the engine will have been totally replaced after this we shoulda done it the first time but **** it we are doing it now.. im not happy about it but it will run good after this stuff... and ya i said posi locks like 9 times so im stuck saying posi instead of poly grrr
BTW can someone post the those pics someone took of the MSD opti when they got it i mean the high res real big pics of the inside of the cap I want to look at it see if what i pushed might have contacted the rotor or anything
GODDAMNIT WHY DO I HAVE TO BE SO FKING STUPID
Originally Posted by the_merv
That is what got broke..or is that a photoshopped pic..
The first thing I can see if that is what happened is water can get in there really easy, and that will kill it fast.
Gun5, what makes you think your lifters are bad? How much spring pressure are you running?
You DO realize, they all collapse when the engine is stopped and that valve is open. . .
Mike
Mike
