SBC heads on an LT1 - Who?
Old 01-09-2007, 09:18 AM
70Stang's Avatar
Default SBC heads on an LT1 - Who?
We are looking for someone to modify SBC heads to fit on an LT1 with a SBC intake.
Anyone have any experience with this?
Thanks!
Old 01-09-2007, 10:01 AM
White 96LT1's Avatar
The LT1 has reverse flow heads. just buy a new top end setup
Old 01-09-2007, 10:15 AM
The Big Show's Avatar
Thanks!
There are a few sponsors on here who do that. Off the top of my head LME is one....
Old 01-09-2007, 12:06 PM
Ls1Bait's Avatar
I think iv seen pics of it done but I dont think its worth it with the number of companys that make heads for these motors.
Old 01-09-2007, 12:15 PM
Dragframe's Avatar
it would be worth the time to ditch the lt1 and go SBC... jsut go that way,..
Old 01-09-2007, 12:19 PM
Tony Shepherd's Avatar
www.portpros.com
Old 01-09-2007, 04:11 PM
96redcamaro's Avatar
i did on my new motor. i went with brodix track 1's and called brodix and talked to them, and they did all the work for me.
Old 01-09-2007, 04:47 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
What did it cost for the conversion???
Old 01-09-2007, 08:03 PM
switch hit's Avatar
Yes I would like to know as well.
Old 01-09-2007, 08:38 PM
FASTFATBOY's Avatar
CFM in Indianapolis did mine $400
David
Old 01-09-2007, 08:48 PM
Ls1Bait's Avatar
what is needed to be done to run SBC heads?
What is the cooling system, and benifits to the SBC heads?
Pics?
Old 01-09-2007, 09:01 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
The benefit to SBC heads is the large number of aftermarket heads to choose from.
Old 01-10-2007, 12:27 AM
TwoFast4Lv's Avatar
Hmmmm........
Like 15 and 18* heads
Old 01-10-2007, 12:34 AM
daniel6718's Avatar
can you not make a sbc work with a lt1 computer...with fuel injection and a single plain conversion, all youd have to do is install a knock sensor and coolant temp sensor...right? o2 in the exhaust and iat and maf in the intake elbow...ect...i thnk i made that sound a little too easy but it doesnt seem like it would be all that hard..
Old 01-10-2007, 12:37 AM
TwoFast4Lv's Avatar
All you need to make a SBC to work is a SBC roller block
Old 01-10-2007, 07:31 AM
70Stang's Avatar
Well...we have a built LT1 already - We want to run gen1 heads so that we can run an unmodified EFI carb style intake for the aluminum elbow we are running...
This is a turbo car, so we would like to be able to switch intakes without having to modify them all the time. Doing the heads once would be better then doing the intakes everytime.
Thanks for the help everyone!
Old 01-10-2007, 08:32 AM
camar0corey's Avatar
So do they modify the heads to work with the reverse flow cooling then??
Old 01-10-2007, 08:46 AM
aggiez28's Avatar
yes...
FASTFATBOY's Avatar
I did the same thing, but mine is normally aspirated, Super Vic and Pro Action 235's. If you are gonna run conventional small block intakes, no need to mess with the intake side holes.
David
Old 01-10-2007, 08:51 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
You can also have the LT1 heads redrilled to accept SBC intakes
