How hard is it to replace the opti?
We replaced the waterpump awhile back, and I think we had to remove the opti, too. I don't remember it being too difficult.
I'm sure it's the opti that crapped out. A couple of weeks ago, it just died in the middle of the road. It just died out of nowhere I think twice more after that. Yesterday afternoon, it started running weirdly so I pulled into a parking lot. Then, it died. Everything would happen, except run. I could hear the fuel pump, it turned over and everything. Last night after several hours, we went back and it "ran" for like 30 seconds then died.
hard to say, you can isolate whether or not it's the opti though, pull the coil wire from the opti, ground to block/head (use some insulate pliars keep from getting shocked if you have old crapped out wires), crank it over check for spark, if it sparks that at least temporarily rules out the coil (which could still be bad, theres a multitest you can do to check the ohms). Now hook back the coil wire and crank it over with say like #1 plug & wire (ground to block/head) if you have a spark there too, then usually the opti is ok. That does not rule out individual bad wires/plugs, but is a quick general test for where you are at least getting spark.
My buddy had no FIRE through the opti, but fired from the coil, yet wouldn't start, turned out the coil was bad, it sparked but was weak, the ohms were out of wack. There is a write-up/how-to of what the ohms should be for a stock coil somewhere, will post if I find it. If your using an MSD BlasterCoil the ohms will be different for determining whether or not it's bad, forgot what was considered good for the MSD.
That is a lot of miles for an opti though.
The plugs and wires are overdue for a change, though. I have those sitting in my room. Should we replace those first? I know they're a pain in the butt, too.
Repeat with plug and wire #1. If it sparks, then the opti is seemingly good.
Originally Posted by Shackleford
So, pull coil wire from opti and ground to block/head. Crank it over, if there's a spark, the coil pack seemingly is good.
You could still quickly check for spark though prior changing any wires, just to see, won't hurt anything.
Yeah if it were me I'd change the plugs/wires regardless just because it's time, and correct if the plus w/boot/wire spark then opti is at least getting spark. That doesn't mean it doesn't have issues, but it's a quick diagnostic is all. The Mitsubishi eye sensor could be bad or dirty, the bearing could be shot on the sensor causing erratic readings of the little timing wheel, yada yada yada.
I have Taylor 8mm wires and NGK plugs. Will I need anything else? Any tips for the plugs and wires change?
TIP: Have someone with super skinny arms do the passenger side wires . I took my alternator off to help with routing the wires through the accesory bracket.
Originally Posted by the_merv
To change the OPTI, if that is worst case, it will take you a bit. Takes me a little over an Hour, but I have a few less things in the way. Might not be that though, check everything close to it. Could be ICM..
If you have spark from the Coil, that's good, but like mentioned before, it might not be enough. If everything is as old as it is(I doubt it, but you never know), it could be the OPTI going. My old Coil was 110k old, it was causing a misfire up past the 5500 RPM mark. I replaced it and have no problems.
