What heads are these?
Old Jan 12, 2007 | 12:58 PM
Jonathan@Tick's Avatar
LS1TECH Sponsor
Default What heads are these?
I was working on a friends car a few days ago, and while the valve cover was off I noticed the heads were deffinately not stock. He just purchased the car and doesn't know anything about what has been done. Its a 95 Formula, LT1. Heres a pic:
The valve springs appear to be 1.460 diameter dual springs, and the are under the valve cover is almost flush with the valve cover rail. Also, the pushrods appear to be too short. I just thought they looked kind of weird, and was wondering what they might be. Any thoughts?
Old Jan 12, 2007 | 01:07 PM
Captainofiron's Avatar
Yea those are definitely aftermarket heads. But I have no clue as to the brand, and its weird that the outer rail is almost the same hieght as the inner recess
Good Question
Old Jan 12, 2007 | 02:00 PM
9formula4's Avatar
well a good indication they had been switched would be the roller tip rockers LOL.
As far as finding out what heads they are they should have a stamp on the side closest to the radiator.
I am looking at pics of the TFS and AFRs and they could be either.
Old Jan 12, 2007 | 03:15 PM
LS1TECH Sponsor
I've done a set of trick flows. They are deffinately not Trick Flow. Trick flow would have TFS stamped under the valvecover. They actually look cheap, I couldn't imagine them being AFR's.
Old Jan 12, 2007 | 05:45 PM
95greenZ's Avatar
maybe edelbrocks?
Old Jan 12, 2007 | 06:02 PM
SStrokerAce's Avatar
Nope AFR's, MAYBE Canfields but they have so much aluminum in there and the oil passages look like AFR that's what my guess is.
Bret
Old Jan 12, 2007 | 07:03 PM
LS1TECH Sponsor
Heres a pic I found of some Canfields, so I guess they are ruled out. The openings for the pushrods are different, and everything just looks different.
Old Jan 12, 2007 | 07:49 PM
Cole Train's Avatar
the rockers say Crane Cams i believe. Look on the inside. Maybe a jegs kit. He's lucky, i wish mine were aftermarket.
Old Jan 12, 2007 | 07:54 PM
edcmat-l1's Avatar
Does it look to anyone else like it has no guide plates and no self- aligning rockers? 5LTREATR, does it have self -aligning rockers? Dont know what the heads are, sorry....
Old Jan 12, 2007 | 07:55 PM
edcmat-l1's Avatar
I think its the Comp Cams logo....JMO
Old Jan 12, 2007 | 07:58 PM
the_merv's Avatar
Veteran: Air Force
What do the Exhaust Ports look like, hope they are not Gen I Heads..
Old Jan 12, 2007 | 08:33 PM
They are early AFR's then.... The rockers are self aligning and they have washers under the studs!!!! Either way get some Pro Mags in there and AFR Guideplates.
Bret
Old Jan 12, 2007 | 08:40 PM
vanilla89's Avatar
Bret
i was going to say some old AFR's.but bret beat me to it
Old Jan 12, 2007 | 09:36 PM
my94blackz's Avatar
Way different than any ive saw before. He asked me, I looked at the pics, and I had no idea. He said the car didnt feel that impressive. Cheap advance heads or something maby?
