Anyone used this elbow?
Old 01-14-2007, 06:22 PM
ABA383's Avatar
Default Anyone used this elbow?
I've been seeing these on Ebay:
http://cgi.ebay.com/ebaymotors/Brand...spagenameZWDVW
...Thought about getting one to replace my 1LE just for looks only...Anyone have any feedback on the fit and finish? Thanks...
--Alan
Old 01-14-2007, 06:26 PM
lt1_man's Avatar
I just bought it and installed it on mine. I had to do some triming on the connectors and they fit a little lose you have to really crank the clamps down. It took me awhile to install because of how big it is but it seems to be holding up alright. The elbow does seem to get pretty hot though.
-Brandon
Old 01-14-2007, 06:28 PM
ABA383's Avatar
Thanks for your quick response...You have any installed pix? The Ebay feedback is mostly positive, but I'd like to see one on the car...
--Alan
Old 01-14-2007, 06:34 PM
APSS's Avatar
I Got The Trickflow Elbow. Had To Trim About 1/4 Inch So I Could Get My Airbox Square.i Put Some Thermo-tec Heat Wrap On The Underside To Combat The Heat.
Old 01-14-2007, 06:37 PM
hyperzone's Avatar
That looks EXACTLY like my trick flow elbow. Instructions look identical... thats funny...
If it is identical, it will fit just fine. Had absolutely no problems what-so-ever with mine. You'll have to drill out the hole for the opti vent line if your using one.
Old 01-14-2007, 06:43 PM
ABA383's Avatar
That looks nice and clean...^^^^ I'm also wondering if I'll have issues with my TB because its the Accel/LPE 58mm and its about 1/4-1/2" deeper than others I've seen and sticks out towards the radiator a bit more...mmmm...Do you have any clearance between your elbow and the TB or is it almost touching?
--Alan
Old 01-14-2007, 06:49 PM
hyperzone's Avatar
^^^ Thanks! I liked the black elbow since its not as obvious and since I'm not really doing any other shiny parts, it kinda fits.
The elbow has about a 1/4"-1/2" clearance between it and the radiator shroud. The K&N CAI rubber coupling (between the maf and big-plastic-K&N elbow) is pressed snug up against the radiator shroud. You can sort of see in the picture from the side there.
Old 01-14-2007, 06:53 PM
96blkform's Avatar
I will be insterested to see some of the reviews, as it really looks like a great alternative to spending $90 on the trickflow. Thanks for posting it up ABA383.
Old 01-14-2007, 07:00 PM
9formula4's Avatar
I got mine off ebay also for 25 bux shipped. It looks good and install took about 5 mins.
here it is:
Old 01-14-2007, 08:07 PM
ABA383's Avatar
No problem...It is much cheaper than the Trick Flow and if it works, then its a good deal...There's nothing wrong with my 1LE elbow, but its kinda squished a wee bit because the LPE TB is bigger/deeper than others, so it throws off the geometry of everything...
Anymore folks out there with this elbow?..
--Alan
Old 01-14-2007, 08:16 PM
9formula4's Avatar
I'd say go for it
Old 01-14-2007, 08:55 PM
Ralls's Avatar
Never been a fan of aftermarket elbows because they are usually shinny. But I like how it's powder coated. Would the heat soak make things worse?
Old 01-14-2007, 09:06 PM
lt1_man's Avatar
I will try to get some pictures of mine but it looks just like the one posted before. Also the intake does get alot hotter then the stock one that is the only down fall so far.
-Brandon
Old 01-14-2007, 10:08 PM
LT1powered89's Avatar
Is the trick flow plastic or metal? Im assuming the EBAY elbow is metal because its getting hot.
Old 01-14-2007, 10:12 PM
NotACop97Z's Avatar
I just bought it too. fortunatly the gay air force lt-1 thing is on the bottom
Old 01-15-2007, 07:58 AM
NotACop97Z's Avatar
Thumbs down
DO NOT BUY THIS IF YOU HAVE A LARGER TB. I WILL POST UP PICTURES LATER. It fits ok on a stock TB but it hinders flow on my 58mm TB.
Old 01-15-2007, 09:28 AM
camar0corey's Avatar
The trickflow elbow is metal. I just got the ceramic coated one to combat the heat. So yes its shiny but I don't care.
Old 01-15-2007, 11:51 AM
ABA383's Avatar
Hey, thanks!...I guess if it ain't broke, don't fix it....I have an LPE 58mm TB and don't need any restriction...
--Alan
Old 01-15-2007, 07:32 PM
NotACop97Z's Avatar
Old 01-15-2007, 07:33 PM
NotACop97Z's Avatar
I have some fat ugly thumbs
Quick Reply: Anyone used this elbow?
