Need help with cam
Adv Duration 296/310
@0.050" 234/242
lift .568"/.544" w/1.6 rockers
LSA 112*
ICL 108*
This is a custom ground cam that I had ground for a customers 383 LT1 with the same type of components. This cam can be used with N2O up to a 400 shot if you would want to get real nasty!
@0.050" 234/242
LSA 112*
ICL 108*
@0.050" 234/242
LSA 112*
ICL 108*
@0.050" 234/242
LSA 112*
ICL 108*
He didn't tune his computer for the new engine and was hitting the rev limiter at 5500 rpm. At the high altitude (5,820 ft actual elevation) Bandemere Speedway in Denver, CO, he ran a 12.75 sec 1/4 mile. His 97' SS weighed 3520 lbs. without him in the car. He was running a TH-400 w/trans brake and a 3500 stall converter. He had a 10 point roll cage in his car and full street trim interior. He had converted his front suspension over to the Hal QA1 coilovers, subframe conectors, lower control arms, BMR rear drag lauch sway bar, Curry GM 12 bolt w/3.73 gears, Hal QA1 rear shocks, softer rate rear coil springs, Jegsteer rear torque arm kit, Hoosier Quick Time Pro Drag Radial 27x10.5x15 tires, and Weld Pro Star Rims.
If you do the math that is a preaty quick pass for a limited motor only pass. The camshaft pulls very, very hard. It is not a GM847 cam by any means.
Originally Posted by Row
Need a cam for a 383 LT4. Auto car with 3600 stall and 3.73. Heads flow 271/190 @ .550. Full boltons and exhaust.
